looking for westerbeke generator parts??? >
Old 11-18-2010 | 03:53 PM
Angry looking for westerbeke generator parts???
I have a 6.5 kw gas generator. Looking for parts. Westerbeke is very expensive. Any info on who makes the parts: gaskets, maifolds, sea water pump. Thanks.
joepequa is offline
Old 11-18-2010 | 05:57 PM
Default bump
hi
joepequa is offline
Old 11-18-2010 | 06:55 PM
I have had some luck on craigslist, typically florida, for some Westerbeke parts. Also, ebay on occasion. But sometimes cheap ends up being more expensive in the long run. No subsitutes for Westerbeke parts, except for those that Westerbeke had other manufacturer's build originally (i.e. raw water pump).
In the instance of the raw water pump, a whole lot cheaper to rebuild yourself than buying another. Rebuild kits are about $100 ish and a new pump was $465 (in my instance). Typical life on a raw water pump is about 5 years. Impellers are different story.
Good luck.
ShadBurke is offline
Old 11-19-2010 | 07:50 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Here's where I get my filters and zinc. Haven't had to do anything major to it. Westerbeke parts through. Not exactly what you're asking.
http://www.boatersplus.com (preferred)
http://www.discountmarinesource.com
Baja_342 is offline
Old 11-19-2010 | 10:13 AM
Default gfj
bump
joepequa is offline
Old 11-20-2010 | 03:21 PM
most all gen parts any brand...bend over grab your ankles...they use a misibitshi engine, the pump you can crossover to japsco pump parts usually
ezstriper is offline
