mystery product needed
Old 11-21-2010 | 09:35 AM
Default mystery product needed
What I need is some product that I can inject and fill in a section 2'X2'X3/4 were there was once plywood. It is a none structure just a deck section that the wood rotted out of and I want to fill in the void with something way more dense than spray foam for sealing windows as it gets walked on. Hope you know what I am trying to explain. Thanx, Andy...
Andy is offline
Old 11-21-2010 | 10:26 AM
How about a piece of starboard? If it has support all the way around it should work for you.
Power1One is offline
use pour foam... its a two part mix and there ar higher densitys.
kvogt8000 is offline
Old 11-21-2010 | 01:11 PM
Have you looked into seacast?
autowerks racing is offline
Old 11-21-2010 | 03:47 PM
What about marine trex or other similar type of epoxy filler?
wjb21ndtown is offline
Old 11-21-2010 | 08:50 PM
glassdave's Avatar
Neno the mind boggler
here ya go, careful with the lighter densities. They have a pretty big ratio of expansion. They WILL blow right out of the fiberglass if not careful. Best to work in small amounts with a plastic syringe. I have used this to repair cores that are not accessable by any other means and i could not break the outer skin. Works great but like i said be careful it will get away from ya.
http://uscomposites.com/foam.html
08 OPA High Points Champion
glassdave is offline
Old 11-21-2010 | 09:58 PM
Looks like the stuff I need, any left over I will use on my late paying customers bung holes. Everyone wants there boats done yesterday but when payment is due they always say tomorrow. I guess payment will follow after there bowel movements, usually in 2-3 weeks.....too funny...
Andy is offline
Old 11-22-2010 | 05:34 PM
can you read this ole friend
SUE C Q is offline
