The 2010 International WorkBoat Show and Livorsi Marine
Livorsi will be exhibiting the International WorkBoat Show taking place December 1 - 3rd at the Morial Convention Center in New Orleans, Louisiana.
Industrial Series Gauges
Designed for the equipment that you rely on, day in and day out, these no-nonsense gauges outlast and out perform all others. These gauges feature fade resistant powder coated pointers; SAE rims in a powder coat finish or in polished stainless steel. Among the gauge line up are pressure, vacuum and temperature gauges. Diesel and gas tachometers are also available.
Vantage View®
For marine and automotive applications, Vantage View® reads and displays performance data directly from CAN (Controller Area Network) for protocols: Smartcraft®, SAE J1939, NMEA2000® Indmar and MEFI4. Gauges are completely digital with an analog face. In addition to factory set warnings, 15 alarms can be set to individual preferences. Triggered alarms give visual warnings in both the in the corresponding gauge (via LED warning light) and the Master Tach LCD. Gauges are l inked with Deutch connectors and plugs for easy installation.
Livorsi Controls
Livorsi control options: mechanical, electronic and digital, all constructed of heavy duty bronze and stainless steel.
Mechanical
Enclosed wiring, adjustable lever resistance, powder coated in a single color for a uniform look
Livorsi ETS- Electronic Throttle & Shift
Livorsi can design your electronic controls to your specific needs. Single, Twin or Triple engine applications available utilizing dual BEI redundancy position sensors. Easy installation made possible with supplied connectors with flying leads. Have the option of keeping the shifters mechanical with the use of 33C or 43C cables.
Livorsi DTS- Digital Throttle & Shift
A license from Mercury Marine allows us to combine DTS (Digital Throttle and Shift) technology with the options and quality of Livorsi controls. Livorsi Smartcraft® DTS controls provide smoother and safer shifting. Direct drive of throttle position sensors results in faster response times giving you complete control of your boat. These controls are designed to work on all Mercury I/O and OB DTS compatible engines. Single, twin triple and quad configurations are available.
CMI Stainless Exhaust
CMI, a leader in stainless exhaust will be co-exhibiting with Livorsi. Products range from headers, tailpipes, diesel risers, electric diverters and their new Gen-X Header.
The WorkBoat show is the largest commercial marine tradeshow in North America serving those working on the coastal, inland and offshore waters. For more information on the show, please visit www.workboatshow.com.
Vantage View®
Livorsi Controls
Mechanical
