Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Best way to seal through hull bolt holes on transom >
Old 12-02-2010 | 07:33 AM
Default Best way to seal through hull bolt holes on transom
I read a thread about it earlier in the year and just spent 45 minutes trying to find it, no luck.
I am closing up the bolt holes from my old bracket and am installing a new Stainless Marine bracket in its place. There are 18 5/8 holes. they juest need to be sealed, there wont be anything bolted in the same holes.
I was going to just go to home depot and get some wooden dowles, trim them and seal around them with microlight/silica. It sounds to ghetto to be the correct way. What is the best way?
the the screw holes from the old swim platform, i was going to Microlite those too with a puddy knife.
sixmassive is offline
Old 12-02-2010 | 08:39 AM
glassdave's Avatar
Neno the mind boggler
heres the thread with the dash and screw holes. Its essentially the same except you use a dowel instead of core plugs. Nope . . . not ghetto at all . I would use a filler with a bit more density for bonding it though West Systems 404 is great this kind of project.
http://www.offshoreonly.com/forums/f...ash-holes.html
08 OPA High Points Champion
glassdave is offline
Old 12-02-2010 | 09:19 AM
thanks, Subscribed!
Old 12-02-2010 | 09:34 AM
im gonna try and hook up a funnel system and mix a slow batch and try to let the wood in my transom absorb the resin, is that possible?
Old 12-02-2010 | 09:47 AM
glassdave's Avatar
is it wet or dry rotted? If not no need to do anything other then use a good high density filler to bond in the dowel. If you wanted to get resin to pull into the void you'd be better off setting up a small vacuum system.
Old 12-02-2010 | 10:03 AM
It is dry, I can just hear a hollow sound when you tap it.
Old 12-29-2010 | 08:34 PM
Default Transom hole repair
I'm changing trim tabs. Most of the old screw holes will be behind the new K-plane transom plate. Should these be filled? Where do i find the West System products. I have two 3/8 holes and about 10 #14 screw holes
Advantage 575 is offline
Old 12-29-2010 | 09:37 PM
uscomposites.com is a good place if you have a couple days to wait (ups)
or if your in a hurry west marine stocks it but, overpriced. (as always)
mung272 is offline
Old 01-18-2011 | 08:27 PM
glassdave,
I have some small rot around the bottom transom bolt holes into the cutout area for the outdrive. I have dremeled out bad material and let dry. what do you recommend for structural filler in this area? I was thinking of using MARINE TEX .
Aaron
Our Scarab 34 is offline
Old 01-24-2011 | 01:14 PM
Originally Posted by Our Scarab 34
glassdave,
Aaron
Im curious as well.
Also can I use resin mixed with micro ballons for holes roughly 1" in diameter in a odd shape? (basically cant use a wood dowel) Ive used it before filling in screw holes and had good luck just curious if it can be used on a bigger hole or if I need a different filler/putty
Pokher Ace is offline
