#6 Rebuild
Old 12-03-2010 | 10:30 PM
maxonmike's Avatar
Default #6 Rebuild
How much should a #6 Drive Full rebuild cost??? The cases are good however all gears, Prop shaft and seals need to be replaced.... Any feedback would be helpful....
maxonmike is offline
Old 12-03-2010 | 11:01 PM
SFOcean's Avatar
Charter Member #394
About 5k for what you need, call Vern at West Coast Drive Service, Lake Havasu City, Az (928) 846-4478
SFOcean is offline
Old 12-04-2010 | 01:15 AM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Call TNT in Miami. Matt can get you fixed up.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 12-04-2010 | 08:36 AM
give Randy at Marine Drive in St Mary Fl a call 352-257-2186
Old 12-04-2010 | 08:41 AM
KNOT-RIGHT's Avatar
5 grand would be a gift.
KNOT-RIGHT is offline
Old 12-04-2010 | 08:45 AM
maxonmike's Avatar
Ocean, Thanks for the reply but do you really think I can get them rebuilt for 5k Each???? My Bravos cost almost that much...
Old 12-04-2010 | 08:51 AM
OldSchool's Avatar
No. I think that he forgot to factor in the price of the gears and propshafts.
You would be better of financially to buy some used ones and have them gone through.
OldSchool is offline
Old 12-04-2010 | 09:34 AM
Pit's Avatar
Pit
Wink
Used could be the same or even worse from what he has now.
Go brand new... 30k a pair???
Pit is offline
Old 12-04-2010 | 10:55 AM
I'll second that........
CignificantOther is offline
Old 12-04-2010 | 12:47 PM
I send my #6's to Craig Colabella of Colabella Performance in St Cloud, FL. Craig used to work for Lake X and his job was to work on the #6 drives among other things. Matt at TNT in Miami is also a top notch drive man. Craig charges $1,000 to tear down and rebuild a #6. Prop shafts are about $1,800 each. Lower gear sets are close to that as well. If you need upper gears add another 2 grand per drive. All seals, propshaft bearings, split line o-rings, drive oil, etc run about $350 per drive. Assuming you have a twin engine application and you are refreshing both drives, you can often swap the lower gears from one drive to the other as they only wear on one side. That saves about $1,800 a drive. If you need to overhaul the whole drive of all parts, figure $7,000+ per drive. If you need just seals, etc (no gears or propshafts) figure $1,350 per drive.
CoolSpot is offline
