34 4 blade vs 32 6 blade >
Old 12-05-2010 | 09:43 AM
Default 34 4 blade vs 32 6 blade
86 Velocity approx 1600hp TRS will turn the 34's 5000 rpm will I pick up any more rpms with the 32 6 blades or get the 34's labbed.
Andy is offline
Old 12-05-2010 | 12:31 PM
You would probably lose rpms at WOT with the 32" 6 blades vs 34" Bravos.
Griff is offline
Old 12-05-2010 | 12:40 PM
On my boat 32 maximus is the same as 36 bravo 1 rpm wise if that helps....
bobsbillets is offline
Old 12-05-2010 | 06:14 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Old heavy boat, TRS deep in the water, 800hp I smell broken drives with the 6 blades. If you want more rpms you need to go down in pitch. Step down to a set of 32's and see if that helps. The depth of the TRS is hurting you. Only my opinion. What trans are you running?
fireboatpilot is offline
Old 12-13-2010 | 05:42 PM
worked over 72c
Andy is offline
Old 12-13-2010 | 05:44 PM
How about labbed 5 blade 32p?
Andy is offline
