Will the eddie marine manifold and risers fit on the 272 stock thru hull transom hole >
Old 12-07-2010 | 10:19 PM
Default Will the eddie marine manifold and risers fit on the 272 stock thru hull transom hole
http://www.eddiemarine.com/store/car...l&p=13075&c=63
The above link is what I'm most likely getting for the engine I'm putting in my baja 272, I wanted to know if anyone else with their 272 has used this exhaust manifold and risers and if it lined up with the stock thru hull transom holes that come from the factory. Stock it had a 454 330hp with just the normal manifold and risers, before I purchase this I just wanted to see if hopefuly other people have used them on their 272 to see if I was going to run to into any problems aligning it with the thru hull tips? (the outdrive is a bravo one)
272bajadriver is offline
Old 12-08-2010 | 12:26 PM
Anybody?
Old 12-08-2010 | 12:44 PM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Should not be a problem, make sure there is no spacer between the stock riser and the stock manifold. We have good prices on EMI Exhaust.
302-521-0123
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 12-08-2010 | 04:11 PM
Thanks, yeah I didn't have any spacer between the stock manifold and riser
Old 12-08-2010 | 09:09 PM
should be good to go call Eddie the guys out there or very helpfull on there products.
lightning jet is offline
Old 12-09-2010 | 01:42 AM
I put the EMI dry exhaust system in my 25OL after water reversion smoked my #1 cylinder valves. Only minor modifications were required and able to be covered by the gaskets and trim rings for the transom. With only 16" pipes you shouldn't have any issues with the rubber exhaust able to flex a little if required. The post above about EMI customer service is correct.
knockld is offline
Old 12-12-2010 | 04:14 PM
When I had EMI Thunders, they fit perfectly on my 500 in my 272, no modification needed!
SmurfOnABoat is offline
