Rotation of Drives >
Rotation of Drives
Rotation of Drives
Old 12-09-2010 | 10:12 AM
Default Rotation of Drives
I have a 1987 Scarab II with 454's in it. Both motors are turning clockwise. I was wondering:
1. If I am able to change the rotation of the drive without changing the whole lower unit?
2. How I would go about doing this and where is the best place to get the parts needed.
U.P.Scarab is offline
Old 12-09-2010 | 10:14 AM
What kind of drives?
Wildman_grafix is online now
Old 12-09-2010 | 10:21 AM
Alpha 1 drives.
Old 12-09-2010 | 05:55 PM
Takes a counter rotation gear housing (lower unit). You can't just run an Alpha in reverse like a Bravo.
BDMarine is offline
Old 12-09-2010 | 06:05 PM
You would have to change the drive or at least the lower unit on one of them.
FYI the Alpha drive was only availiable for 2 years for use with the 454. They never held up well to the torque of the big block so the Bravo came into play.
Here's a link to a site where it's mostly Alpha and Bravo guys. I'm sure you can get a lot more Alpha information over there.
http://forums.iboats.com/
picklenjim is offline
Old 12-11-2010 | 09:32 AM
The change is made in the lower unit, no need to change the entire drive. I am not sure if you can change internals and use the same case, or if the case is different as well, likely a good drive guy can answer that for you. Had this done many years ago on a 32 Pachanga with 454 / 330's. I put 550 hours on that boat over six seasons and never had an issue with the Alpha drives.
Wish I could say the same about the Bravo's I've owned since then.
RaggedEdge is offline
Old 12-22-2010 | 01:10 PM
Thanks for the input, now the question is where to buy the parts needed to make the change, any suggestions?
Old 12-22-2010 | 03:50 PM
fireboatpilot's Avatar
RIPSTA Racing Team
IMO Do yourself a favor now and start looking for a set of Bravo's. You can pick up a set of drives and gimbles for cheap from someone doing an upgrade and save yourself the aggravation of having to repair the Alpha you just spent $ on. The Bravos will hold up better than the Alpha's, their nothing great either just a bit stronger and it's a pretty simple swap over.
fireboatpilot is offline
Old 12-22-2010 | 04:19 PM
Too Stroked's Avatar
Remember that a straight swap for Bravos will loose the OP some speed as a favor for giving him a more robust drive in his application. Yes, most 454/330/Alpha combinations blew up a long time ago. But, if you've very careful with them and have a relatively light boat, they can actaully last. One guy up here has a 22' Pachanga with that combination and it's never blown up. Of course the guy babys the hell out of it ..
Too Stroked is offline
Old 12-22-2010 | 04:57 PM
If you plan to stick with the Alpha you might want to check these out.
http://www.sterndrive.cc/mm5/merchan...ercruiserAlpha
