Can a labbed 25 run 80 on a 311 >
Old 12-10-2010 | 03:22 PM
Default Can a labbed 25 run 80 on a 311
trying to figure out the speed of my boat it pegs out at 75 in my 311 with 525hp sets on the vdo emblem.
pgolder is offline
Old 12-10-2010 | 05:01 PM
I would say its possible but you would have to be turning them over 5600rpms (guess of top of my head) and have pretty low slip #. What rpm you turning? I get 75-76 at 52-5300 rpms non labbed 25's in a smaller boat.
hotjava66 is offline
Old 12-10-2010 | 05:57 PM
5200rpm with 25s and it will go way past the 75 on the speedo
pgolder is offline
Old 12-10-2010 | 06:38 PM
If you can spin the 25's at 6000, have a real slip factor of 15%, you would in theory run 80.492423 MPH !!! It's all in the math.
RaggedEdge is offline
Old 12-10-2010 | 08:39 PM
Only sure way is to GPS it, mechanical speedo's can vary.
Old 12-10-2010 | 10:40 PM
Ted G's Avatar
My stock 26 Bravo 4 blades go 72-73 at 5250 on a 311 with 1.5 Ratio Bravos.
www.cbpba.com
Ted G is offline
Old 12-10-2010 | 11:27 PM
1.3 gears in the drives, then no problem.
JMS322 is offline
Old 12-11-2010 | 01:23 AM
A 1986 VDO speedo is probably about as accurate as a $2 watch.
You need to get a GPS speed.
Griff is offline
Old 01-04-2011 | 02:09 PM
billeickmann's Avatar
1992 Formula 336, Mercury Mirage Plus 25" props, slightly built HP 500s. Vdo speeds 76 to 80 mph. Gps speeds 70 to 72.5
billeickmann is offline
Old 01-04-2011 | 05:12 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
13% slip (a good # for that hull when set up well) would require 5826rpm to get 80mph
Brett
[email protected]
bbladesprops is offline
