(2) Combo oil/trannny coolers for 700hp motors.... >
Old 12-21-2010 | 01:35 PM
Default (2) Combo oil/trannny coolers for 700hp motors....
anybody have two that they will part with?????
302Sport is offline
Old 12-22-2010 | 07:39 AM
700 Hp?
kreed is offline
Old 12-22-2010 | 08:04 AM
i talked to bob madera and he said this year i should be making around 620hp with his cams and by changing to dominators. Next year I plan on doing changing the heads so I should be around 700hp. So, I dont want to have to change the coolers again. How much power are you making and what are they?????????
302Sport is offline
Old 12-22-2010 | 08:18 AM
They are 572 Tall decks. Just over 700 each. Dominators, brodix intakes and heads. 10 to 1 Comp, rollers, CMI's. BUT!!!! Its a heavy 40ft sled!!! Stelling boxes and Imco extremes. 80 MPH. This setup in your boat would be SWEET.....and fast!!!!
kreed is offline
Old 12-22-2010 | 09:08 AM
yeah my boat would prolly run over 100 with that set-up.
302Sport is offline
Old 12-27-2010 | 02:18 PM
Not sure you will find a combo cooler that will support 700HP and cool the tranny together. Might be better off going with separate coolers. maybe a 3x18" oil cooler, and then a smaller one for the tranny. Mount the oil cooler behind the distributor (like a HP500) and mount tranny coolers on starboard side of engine block under exhaust manifold, sea pump hose going right into it. Maybe run a combo cooler for the trans and power steering if you need to do so on the starboard motor, same location.
MILD THUNDER is offline
