single ram to dual ram steering >
Old 12-24-2010 | 06:00 PM
Default single ram to dual ram steering
I have a single ram hydraulic steering, it is full not add on. Not sure of the brand. What would be involved to convert it to dual ram? would i have to change the helm ( it has 4 hoses on it) or can i just add another cylinder
floyd7811 is offline
Old 12-24-2010 | 06:46 PM
monstaaa's Avatar
4 lengths of hose , 12 hose ends, 2 tee's, 10 908 fittings, and some p/s fluid. it will add right on. i would check the c.c's of the helm unit. you can look on the back of it behind your dash. its probably a charltnn. they or that type are most common. you may notice a slight difference in steering feel at idle if the helm is a small c.c unit.
monstaaa is offline
Old 12-25-2010 | 08:58 AM
blue thunder's Avatar
If the number of steering wheel turns lock to lock was say 2 with single ram, it will be 4 with dual ram using the same helm.
blue thunder is offline
