GPS speedo stuck >
GPS speedo stuck
GPS speedo stuck
Old 12-27-2010 | 01:27 PM
Default GPS speedo stuck
GPS speedometer stopped working right at end of season.
Any suggestions were to start looking for problem.
Will check connections - do these have any common problems?
rgv380 is offline
Old 12-27-2010 | 01:42 PM
Dave M's Avatar
Veteran: Navy
Probably a dead battery in the antenna. Do a search for GPS antenna battery and you will find lots of info.
Bottom line....$$$$ to get it fixed or you can connect it to your GPS for free.
Dave M is offline
Old 12-27-2010 | 01:56 PM
Usually if the battery in the antenna takes a $hit, the needle on the speedo goes to around 10 oclock position with key on.
You can get a new antenna. Some have replaced the battery with success. I wired mine to my chartplotter to send the speedo its signal.
MILD THUNDER is offline
