454 mag mpi rebuilds or pro chargers? >
Old 12-29-2010 | 03:46 AM
Default 454 mag mpi rebuilds or pro chargers?
I have a pair of 1997 454 mag mpi's in my 312 Fastech low hrs about 215. What I would like to do is stroke them, Cam and maybe heads.. I had some Canfield heads on another boat with 502's and she thumped. I already have up graged exhaust and breathers.
I know I will need the ECM recalibrated to what ever I do. Does anyone know if the existing fuel injectors will be ok?
Has anyone done this and have ideas.
Or since I have low hrs. would it be cheaper to add pro-chargers?
silent lucidity is offline
Old 12-29-2010 | 07:22 AM
Knot 4 Me's Avatar
If you stay NA, the stock intake will be a limiting factor. I would post what you are looking for in terms of a MPH increase and what your budget is. That will help in determining the best route to take.
Knot 4 Me is offline
Old 12-29-2010 | 07:48 AM
I dont think you will gain much out of them with keeping the factory MPI system. You can stroke them, add a better cam, roller rockers, run a carb setup, and get about 550HP or so out of them.
Or go forced induction.
MILD THUNDER is offline
Old 12-29-2010 | 10:32 AM
It really all depends on the power you are after. As mentioned, the stock intake will only work well with a Procharger. The stock injectors are good to about 600 hp, but you won't make that N/A.
If you want to stay N/A, then switch out the intake for something like the setup from Holley. That intake with some heads and canshaft will make some good power.(approx. 550 hp).
You may also want to look for a good used side mount Whipple. I have ton quite a few of these and they work great.
Which ever route you take, you will need to make sure the fuel system is up to the task. That means a new pickup in the tank, fuel lines, larger fuel filter head, etc.
Here are a few shots of the Holley setup on a couple of different engines in case you haven't seen it.
Give me a call if I can help in any way. Good luck.
Eddie
Attached Thumbnails 454 mag mpi rebuilds or pro chargers?-650-efi-16-.jpg   454 mag mpi rebuilds or pro chargers?-650-efi-20-.jpg   454 mag mpi rebuilds or pro chargers?-shane-547-efi-41-.jpg
Young Performance is offline
Old 12-29-2010 | 12:55 PM
Procharger is going to be the most inexpensive and easiest way to add real Hp. Procharger + ECU recalibration would likely net you near 500hp without upgrading your fuel system much, and add later possibilities of more HP with heads/cam, etc. You will be under $5k per motor (should be around $4k). Heads, cam, time, intake, carb, fuel system upgrade would likely net more Hp, but it will cost $7K + and be a LOT more work (and will also require more tuning, and maintenance, IMO).
All depends what you want out of it.
wjb21ndtown is offline
Old 12-29-2010 | 03:14 PM
Default Fixx
I know of a 22 classic with the same power you have,he added a procharger and a imco shorty and it will crack 90..
FIXX is offline
Old 12-30-2010 | 11:47 AM
articfriends's Avatar
You could have the manifold ported and get the throttle body's bored if you want to add more hp and still look stock, it worked for me, Smitty
articfriends is offline
Old 12-30-2010 | 07:07 PM
Default pro chargers may be the way
I'm running 73 mph now with the 454 mag mpi's at about 5200rpms on labbed bravo 1 30's...My goal is 80 but don;t want to scatter the motors either..I know tuff to have both.
The picks I have seen from others are all of fuel injected (throtle bodies) mine is an MPI with the plenum.
Who makes the most relable super-chargers??? thoghts????
Old 12-30-2010 | 08:16 PM
Who can do this work, and knows what they are doing?
RaceRPM is offline
Old 01-01-2011 | 05:03 PM
Sporl Performanc's Avatar
Ron Sporl Performance
If you want to stay NA with the MPI fuel sytem, you will need to go to about 540 C.I. It will take a good amount of work and money. We have done numerous ones over the years, and they make a little over 600 HP, makes lots of torque at a low RPM & it will also look stock. Give me a call if you have any questions.
And if you got your hands on a 500 EFI, we convert those to make over 675 HP with 735 ft lbs of Torque.
See the attatched dyno sheets below !
Attached Thumbnails 454 mag mpi rebuilds or pro chargers?-002.jpg   454 mag mpi rebuilds or pro chargers?-003.jpg
Ron Sporl Performance 504-616-6005
Custom High Performance Marine & Racing Engines,Full In House Machine Shop,Custom Rigging & Other Performace Applications. www.ronsporlperformance.com
Sporl Performanc is offline
