Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
How many gallons of paint?????? 33 Powerplay??? >
Old 01-04-2011 | 03:20 PM
Default How many gallons of paint?????? 33 Powerplay???
Mostly one color...........
302Sport is offline
Old 01-04-2011 | 03:37 PM
rchevelle71's Avatar
rchevelle71 is offline
Old 01-04-2011 | 03:49 PM
Its PPG Vibrance 3 stage. Hull side and deck. First stage is orange, then pearl, then clear. ?????
302Sport is offline
Old 01-04-2011 | 06:54 PM
Steve 1's Avatar
The last 33 deck I shot took a gallon of sterling mixed, add the sides and 71 is right between 2 and 3.
Steve 1 is offline
Old 01-04-2011 | 08:19 PM
3 gallons reduced ready to shoot??????
302Sport is offline
Old 01-04-2011 | 08:58 PM
I would say 3 gallons reduced, or 2 gallons before mixing, but may be slightly more, I amnot familiar with the Powerplay freeboard, and depends how many coats yer putting down.
Old 01-04-2011 | 09:12 PM
Default Fixx
it took me 3 gallons of imron @ 4 coats to do a 18' boat,but that was top,bottom and the inside.
also it depends on how much pearl you want to use,back in the day i would lay on the base coat,shoot on a coat of clear to reflect the pearl then clear over the pearl with 4 coats then wet sand and buff.
FIXX is offline
Old 01-04-2011 | 10:20 PM
glassdave's Avatar
Neno the mind boggler
yikes what kind of gun were you using? I did a 42 Tiger w/graphics and tripple coated in DCU2021 and only used six quarts of clear (deck and sides). I was using an Accuspray Turbine though, wicked efficient gun. Also did a 36 Skater last summer in PPG Concept single stage (deck,sides,cockpit,bilge,dash,partial tunnel) still only used three gallons that was through a devilbus GTI gun.
for the 33 PP i would probably get two gallons of base and a gallon of the pearl and two gallons of clear.
08 OPA High Points Champion
glassdave is offline
Old 01-04-2011 | 10:29 PM
thanks dave i will start with that. my paint guy is 5 min down the road so if it runs low i can run down and grab some. I dont want him mixing more than I need for the paint and pearl cause its custom and big $$$$, plus since its custom he wont take back what I dont use haha. Im going with the PPG Vibrance Oh-So Orange. Same paint as the orange donzi zrc.
302Sport is offline
Old 01-05-2011 | 06:33 AM
SS930's Avatar
That should look really sharp Adam. Any graphics, etc?
Are you close to being ready to shoot it? Post up some pics as the project comes along!
SS930 is offline
