im water flush kit
Old 01-07-2011 | 07:34 AM
Default im water flush kit
Does anyone make a kit to add a valve so that when your in salt water you can flush you motors out. I have the hose hook ups in the bilge already, but i dont have the valve to shut off the water coming from the drive.
what are my options
Boomer35 is offline
Old 01-07-2011 | 07:54 AM
CigDaze's Avatar
I just installed some brass 90-degree inline ball valves on the input side of my sea strainers to handle this. I don't remember off the top of my head what size they were though; I want to say 1" or maybe 1-1/8", but don't quote me on that. I got them from a local plumbing supply house. One side simply threaded into my sea-strainer, and on the other side I got an adapter that goes from threaded-to-barbed so I could attach and clamp the hose that comes from the drive.
CigDaze is offline
Old 01-07-2011 | 07:59 AM
CigDaze's Avatar
Something like this:
http://www.mcmaster.com/#47865K25
CigDaze is offline
Old 01-07-2011 | 08:10 AM
Ted G's Avatar
It can be difficult to plumb in a valve when you have that one hose from the drive to the water pump. I had these : http://www.westmarine.com/webapp/wcs...classNum=10439
On for a couple of years and they do what you want, shut off the raw water when a hose is hooked up. But I found both of them cracked last year from vibration so I took them off. You could add some hose and a valve like Nick said, you just have to be creative.
www.cbpba.com
Ted G is offline
Old 01-07-2011 | 08:41 AM
i fought water temp after my rebuild and it was hell, chased around the problem until i finally just redid everything, pumps, impellers, etc...
i was a little concerned throwing in a valve like that would reduce the diameter of the hose and reduce the amount of water, thus run high temps again...
im probably over thinking this,
Boomer35 is offline
Old 01-07-2011 | 08:43 AM
Originally Posted by CigDaze
that is exactly what i was thinking of doing
Boomer35 is offline
Old 01-07-2011 | 08:50 AM
My 88 Formula came with 1-1/4 ball valves and extention handles so that you could easily turn them off and on, but it had TRS drives with separate water intakes. There isn't enough pressure drop through the valve to worry about, but don't the Bravo drives have a seacock to keep the boat from sinking if a hose ruptures?
JTeam is offline
Old 01-07-2011 | 09:25 AM
I would have to assume no, changed an impellar in the water on with bravo x drives, the intake hose was like a firetruck when below the water line.
4bus is offline
Old 01-07-2011 | 09:28 AM
CigDaze's Avatar
Exactly. Same here. That's the other reason a shut-off from the drive is beneficial. Anyone who's ever changed an impeller in the water knows not to ever lay that hose down in bilge. Keep it up high.
CigDaze is offline
Old 01-07-2011 | 09:37 AM
fantastixvoyage's Avatar
Parker stores carry 'em as well and usually have them in stock.
fantastixvoyage is offline
