IMCO Power Flow or CMI Sport Tube >
Old 01-07-2011 | 08:10 AM
Default IMCO Power Flow or CMI Sport Tube
I was wondering if anyone out can tell me if I was to install the CMI sport tube headers on a 3.3 whippled 598cu.in big block if there would be an increase in hp and torque. With the IMCO powerflow manifold as tested on the dyno numbers came in as 951.4hp and torque 910.9 @ 5600rpm. How much gain would I get by installing the cmi's roughly?I haven't dyno'd with the cmi's and probably won't.
campionchase910 is offline
Old 01-07-2011 | 02:05 PM
c'mon you motor heads, someone must have an idea
Old 01-07-2011 | 04:08 PM
JimV's Avatar
My guess is you will see an increase in torque at lower rpms and even up at the higher rpms.
JimV is offline
Old 01-07-2011 | 05:33 PM
I don't think u would see much different # since its a forced inducted engine !!!
If anything i would stay with the IMCO hence reliability.
30Special is offline
Old 01-07-2011 | 05:55 PM
Talking
thanks guys,so the I should keep the IMCO's on. I have the CMI's also
Old 01-07-2011 | 07:37 PM
KEEP THEM ON !!!
Old 01-07-2011 | 08:57 PM
I would think so also. Even with forced induction, i would think the engine would benefit from the increased flow of a true header.
But you are at 950HP now. Even if they got you to 1000 each, i dont think it would be worth much speed wise.If you had dynoed with dyno headers, your numbers would prob be higher. 950 thru yours i'd say your doing good!!!!!
MILD THUNDER is offline
Old 01-07-2011 | 09:04 PM
GPM
What's the ID of the Sport tube primaries ? how much boost are you running ? what heads ? what cam ? Small heads, small cam, low boost, 1.875 primaries probably won't make much difference.
GPM is offline
Old 01-07-2011 | 09:49 PM
Not to sure of the primaries on the cmi's but the cam is cam is a 262 intake with .680 lift 264 exhaust with .632 lift 114 center line
8 lbs boost.Dart Pro 1 heads
Old 01-07-2011 | 10:10 PM
GPM
Did you call Whipple ? Dustin would probably have all your answers, might save you some money.
GPM is offline
