Freeze plugs >
Freeze plugs
Freeze plugs
Old 01-10-2011 | 11:15 AM
Default Freeze plugs
Ok, here is my delima. I have a gen 5 BBC, I have a few oil leaks to work out so I pulled the engine this fall. I have the engine on a stand with the valve covers, oil pan and manifolds removed. I pulled the drain plugs on the block and the water started draining. I assumed it would continue to drain but the right side apparently clogged up. So here is the bad part, the freeze plugs popped out of the right side of the engine, the side with the starter. I am going to have it magnifluxed, what do you guys think?
jeffswav is offline
Old 01-10-2011 | 12:03 PM
Not a good sign, sounds like it froze at some point. Get it checked.
ThisIsLivin is offline
Old 01-10-2011 | 12:06 PM
Ohh yea, it definatly froze on the one side. Water level was about half drained though.
jeffswav is offline
Old 01-10-2011 | 12:21 PM
if the plugs pushed out, they did their job.
Griswald is offline
Old 01-10-2011 | 08:53 PM
From a previous post. Do a search on this topic.
The term "freeze plug" is wrong. They aren't there to keep the block from cracking if frozen. It just happens that they sometimes pop out when the coolant freezes.
Proper term is 'Core Plug". That's how the foundry gets the sand core out after casting the block.
You are doing the correct thing by testing the block. If you don't see a crack you probably will be good.
1BIGJIM is offline
Old 01-10-2011 | 09:19 PM
WRONG!!!!!!!!!!!!
Jeff P31 is offline
Old 01-10-2011 | 09:22 PM
X 2 What jim said
Jeff P31 is offline
Old 01-10-2011 | 09:50 PM
Good idea. You can also have them pressure tested. Man that sucks.
picklenjim is offline
Old 01-10-2011 | 10:24 PM
Yea, I will probably do both. Problem is the engine is fully assembled, to magneflux you have to use iron dust. Not good for the internals. I was just woundering were the problem areas are.
jeffswav is offline
Old 01-10-2011 | 10:40 PM
Pressure test will tell the story fast , and easy to do. If it will not hold pressure it will have to come apart anyway. good luck
Jeff P31 is offline
