Battery mess >
Battery mess
Battery mess
Old 05-16-2002 | 02:00 PM
Default Battery mess
i have 4 batteries with bat. charger, bat. switch, sub., ext. all tied in to a jumbled up mess. so i was thinking of clean things up by installing a bus to take all my connections to. LEGALLY what is required? i have been told that if batteries are located in the engine compartment they need to have insulation covers over the terminals. is this true? and would a bus require the same? if so, what kind? would something like a rubber flap be sufficient?
Thank you,
dean campbell
dean campbell is offline
Old 05-16-2002 | 02:08 PM
MKast
I was told the terminals had to be covered because of arcing.
You can check at www.uscg.mil for more info.
If you go the buss route get the stainless steel lugs, the copper ones fall apart.
Old 05-17-2002 | 11:56 AM
HavasuCat
My DCB does not have covers on the terminals, and I have passed inspections. I am not sure what the actual law states.
BAJA WILL
02-26-2008 08:12 PM
tpmarine.com
New Products and Member Discounts
4
02-02-2006 09:50 AM
luvlake
0
03-16-2004 04:55 PM
RebarBox
09-13-2003 10:16 PM
