502 Parts
Currently for sale:
Two sets of 525 EFI Cams with Morel lifters 65hours
$430.00 each
Two GM forged 502 cranks with Eagle H beam rods with pistons These are for .30 over bore.
One set is mini dome Diamond piston
The other set is a flat top Manley piston
The sets are balanced and in great shape.
Gen 6 engine
$600.00 each
Two sets of 502MPI intake comes with injectors, throttle body, fuel rail, tps sensor, IAC valve, water temp sensors, along with intake bolts. These intakes are in great shape and have been mildly ported to increase air flow. Intakes have been used in fresh water and it shows!
$675.00 each
I can email you pics of the intake now, The cams and rotating assemblies are still in the boat which will be taken out in 2 weeks.
My email is [email protected]
$430.00 each
Gen 6 engine
$600.00 each
$675.00 each
how much for the just the cranks and rods and are they for 2 pice or 1 piece rear main seal and do they need ground my email is [email protected] thanks
