Cobalt 263
I would know if the 263 has a toilet inside...and what do you think about this model?
Here is the boat that I'm considering :
http://usato-barche.vivastreet.virgi...t-263/18501038
Where is the boat? It is a clean one from the pics (pics can not show the whole story) but a good start, i had several customers that loved there 263s good solid all around boat make sure the head is pumped out. it is located under the step into the cabin and if not pumped out regularly can leak and stain the carpet in the cabin ( it pulls out like a drawer) . also the cabin door drains need to be kept clean or can leak in to the cabin. nice all around day cruiser
How many passengers can I carry on it? I guess around 6....
I don't really understand where's the head that I have to check....I have to pull out the step and under it I will found the head that has to be clear and without water..right?
here are a few pics that will help you with the head location, Pass about 6 without sitting on each other, The boat itself is a good all around day cruiser not a rough water boat (ride wise) but will handle rough stuff ok. had plenty of customers use them in the ocean,
It's not going to run in the 58ish, sadly. Expect around 52-55..
The boat you're looking at looks nice and clean
but the antifouling and tower will shave off 1 or 2 mph at the topend.
http://www.boattest.com/boats/boat_v...99#Test-Result
but the antifouling and tower will shave off 1 or 2 mph at the topend.http://www.boattest.com/boats/boat_v...99#Test-Result
Propped with a set of F5s or F6s and salt water 55-58 is a real figure we sold a lot of 262s and 263s that ran that speed no problem in a light chop on salt water on GPS. depending on the type of bottom paint may be a variable ablative vs non ablative.
