oil cooler lines >
oil cooler lines
oil cooler lines
Old 01-20-2011 | 05:57 PM
Default oil cooler lines
is -10 oil cooler lines good enough for my 555cui engines or should i step up to -12
88scarab is offline
Old 01-20-2011 | 06:25 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Yup it's gonna be squeezed down at the fitting either way and 12 is harder to run. You are talking about the oil lines to the cooler right?
fireboatpilot is offline
Old 01-20-2011 | 06:39 PM
If you need to buy hose and fittings buy from here it's the best place to buy from they have the cheapest price I run -12
http://www.aeroquip.cc/aeroquipracefittings.aspx
Rockfish71 is offline
Old 01-20-2011 | 06:48 PM
from the oil adapter to the oil cooler and then to the remote oil filter housing and the cooler gets plumbed in on the in side correct not after the filter housing
88scarab is offline
Old 01-20-2011 | 09:18 PM
I like filtering the oil before the cooler.
MILD THUNDER is offline
Old 01-20-2011 | 09:45 PM
Default Fixx
+1,,before it distroys the cooler if the engine xplodes
FIXX is offline
Old 01-21-2011 | 12:20 AM
Not only that, hot oil filters quicker than cooler oil.
#10 is fine. That's what I use.
Eddie
Young Performance is offline
