6.4 DPF delete
Does anyone make a stand alone dpf delete chip? I want to gut my DPF and reinstall as stock. It will throw a code and the dash light should stay on ? I need the "No Lightie Thingy"
I believe the DPF-R 4.0 is similar to what your looking for - - it doesn't add a HP tune, only used to eliminate the DPF, eliminate regen and the truck from throwing codes
http://dpf-r.gearboxz.com/products.htm
Why gut the DPF? Only took me an hour in the garage to do my entire DPF/DOC delete with common hand tools. I would think it would go right back in just as quick. I am currently running DPF/DOC delete, egr delete, s&b cold air kit, and mbrp cool duals all of which can be returned to stock with normal hand tools when I trade.
I would recommend you NOT gut the DPF. Use a delete pipe instead. If you need warranty work done you may need to reinstall the DPF for warranty purposes, they are also very pricey to replace(like thousands) if you ever had to for emissions BS in the future.
Here in Californication......the scales randomly look under the truck. Sooo it needs to look stock. I got a DPF from the local junkyard for $250. I will save the intact unit for future use.
