plugs in prop hub? >
plugs in prop hub?
plugs in prop hub?
Old 01-21-2011 | 03:37 PM
Default plugs in prop hub?
I have just picked up a set of 32p 5 blade merc props that have been labbed. These props are going on my 87 30' Velocity trying to get my slip numbers down from 24%. Running with 34p bravo1 now. What the hell are the little plastic plugs for and will 5 blades work with my pad hull. Spring is a long time to wait for testing, just wondering if anyone has tried this combo. TRS drives with cones, low 90's @ 5,000ish. I need more seat time, sometimes gets a little squirly with my drive and tab settings so looking at the tach is hard to do.
Andy is offline
Old 01-21-2011 | 06:55 PM
Rookie's Avatar
Andy, I can't help you, but what cones are you running? I am looking to add nose cones to my TRS this winter.
Rookie is offline
Old 01-23-2011 | 01:31 PM
The plugs are to allow the props to aerate/caviate a little when getting on plane. They make plugs with different hole sizes to allow more or less air. They should not effect top speed numbers or slip numbers.
Griff is offline
