thoughts and opinions please
ive got a 4700 lb v bottom with a 500 efi with ALOT of play in the upper verticle pin and was going to purchase a complete HP assembly...whats your opinion on that VS this http://www.offshoreonly.com/classifi...o37483-en.html
yes they drill 2 holes in the side/top of the transom assembly and install dowel like pins...this one is beyond a half assed repair anyway but thanks !
Bernie,
Yesterday, I removed a 2 year old Merc HP gimble ring from my boat. I'm going with SCX drives. I have the top pin and side pins. The top is just the standard merc. Ron's is nice. I am going to list it in swap shop for 350. Bruce's new transoms would be a good option. I'd say look at what all your gonna need to do. Probably new bellows, how does the helmet and the transom look, corrosion?
If we talking about the same thing, there is actually a nother "replacement" buletin. Replacing the whole nut and pin, with out removing the gimble and/or transoom plates. Repaired from the exterior. However, since I had similar problem on one of my older boat, efter some discussions with Merc. and misc. gurus, the best bet is to get external/hydraulic steering. Then those "pins" don't even need to be there.
