IMCO v.s Merc Sportsmasters Lowers >
Old 01-23-2011 | 07:10 AM
LV's Avatar
LV
Default IMCO v.s Merc Sportsmasters Lowers
Does anyone know what the difference is on the 2 sets of XR lowers, the good and the bad?, thanks?
LV is offline
Old 01-23-2011 | 08:41 AM
Imco is more hydrodynamic, faster, on most set ups. It is less expensive than the sportmasters. Both of them use the same gears with mostly the same parts. The sportmaster case is very strong. Both have low water pickups, I like the sportmaster better because it will filter out larger debris. The Imco is available polished, satin, and black. Sportmaster, satin only. I think both are good units, nod for me goes to IMCO because of price and hydrodynamics.
SkiDoc is offline
Old 01-24-2011 | 10:12 AM
LV's Avatar
LV
cool thanks, does anyone need a set of 1 1/4" std Length Lowers? they came off of 2005 XR swept Backs! thanks
LV is offline
Old 01-24-2011 | 05:01 PM
SCRAPMAN1's Avatar
ON A HIGH X DIMENSION FOUNTAIN I HAD WATER PRESSURE PROBLEMS WHEN I WENT FROM MERC 2 INCH SHORTIES TO IMCO 2 INCH SHORTIES. THE PICKUPS WERE MODIFIED WHICH SOLVED THE PROBLEM HOPE THIS HELPS YOU FYI.
SCRAPMAN1 is offline
Old 01-24-2011 | 05:54 PM
aRE THEY LOW WATER PICK UP AND HOW MUCH. EMAIL ME [email protected]
rssteiny is offline
Old 01-25-2011 | 07:56 AM
LV's Avatar
LV
PM sent!
LV is offline
Old 01-26-2011 | 09:02 AM
racer-x6's Avatar
PM sent!
any pictures and what are you asking for them?
racer-x6 is offline
Old 01-26-2011 | 02:47 PM
Anybody know for sure how much faster (if any) the imco lower is versus the sportmaster?
bobsbillets is offline
Old 01-26-2011 | 05:49 PM
LV's Avatar
LV
3600.00 I will handle shipping
I will post pics tomorrow, need them gone
LV is offline
Old 01-26-2011 | 05:53 PM
The main difference is that the sportmaster has a longer skeg with more surface area. Any difference will depend on toe setting and drive deflection as well as the top speed being attained. With high drive heights, some boats don't handle as well with shorter skegs. If you already have sportmasters you could experiment with shortening the skeg, but it is difficult to go back!
Falcon is offline
