Crane Golg Roller rockers...2 sets...really different >
Old 01-25-2011 | 04:06 PM
Default Crane Golg Roller rockers...2 sets...really different
I bought a set of BBC crane gold roller rocker from a guy here. Got them just fine. Just bought another set on ebay and when I compare them they are totally different.
Both say crane, both say 1.7 but are a different gold color, one set is twice as heavy and twice as wide.
Anyone know why, what I have here, or more important if this matters????
Maybe just newer and older models or something?
Baja226sport is offline
Old 01-25-2011 | 04:16 PM
Sounds like you have one old school set and one newer set. It won't really mean much in performance gain/loss, as long as they all roll smoothly, and they're all the same ratio.
wjb21ndtown is offline
Old 01-25-2011 | 04:18 PM
The wider one is rated for a heaver spring 900 lbs to the narrow like 600 or somthing
toolsinbox is offline
Old 01-25-2011 | 04:56 PM
I am not new to the game but I didn't know different rockers were for different valve springs....
Can anyone help me post pick to see if anyone can identify these 100% for sure?
Old 01-25-2011 | 05:02 PM
They did make some changes on part # 13750-16
from old to newer ones, but it's mostly up around the
push rod area where you notice the difference.
JaayTeee is online now
Old 01-25-2011 | 05:55 PM
Sounds like you have a standard set and a Wide Body Set. They are different part numbers if I remember right, I looked at them but wound up using the Comp stainless.
jeffswav is offline
Old 01-25-2011 | 06:31 PM
Jegs has a marine tech who should be able to tell you exactly what they are. 1-800-345-4545
Benchchemist is offline
Old 01-25-2011 | 07:22 PM
go with stainless ! i did . i had aluimana roller rockers and the tip broke . .i got lucky the broken parts didn t fall in the motor i stop the boat2 hours from home and had the old stamp ones in my tool box i replace it then on my way . they were warrity for life wow they gave me a new one.i replace the whole set. i would spent a little more for the best . the ones jeff got are good
bajabob is offline
Old 01-25-2011 | 07:51 PM
2 mins 2 late....already bought 2 sets of these....sell them maybe???
Old 01-25-2011 | 08:22 PM
If they are the Crane Golds a lot of guys are using those. They are what come in the Merc Racing engines. I used the Comp Stainless because I heard they were better and they were about the same price.
Bob what brand of rocker did you break? It seems like I saw a pic somwhere.
jeffswav is offline
