Do aluminum heads make a difference? >
Old 01-29-2011 | 09:18 AM
Default Do aluminum heads make a difference?
I have two stock 502 MAG MPI's with 220 hours. I have a chance to purchase two new sets of aluminum heads at a great price. But it sounds too good to be true that I can just bolt on aluminum heads and get more power. Do I have to change timing, cam, exhaust, etc... to get any hp gains. Thanks.
NKissau is offline
Old 01-29-2011 | 09:41 AM
yes aluminum heads make a difference
but it is a combination of things that will make the hp
bottom end ,cam,heads and intake
Centsless is offline
Old 01-29-2011 | 10:18 AM
Rookie's Avatar
Depending on the head, how it flows and what compression ratio it ends up. Yes it can increase power quite a bit. Also maybe a 200# weight saving on a twin application.
Rookie is offline
Old 01-29-2011 | 11:17 AM
Remember you get what you pay for, if its sounds to good there is a reason.
If they are an off brand you could spend more in machine work than they are worth. You need to find out what kind of valves are in them, what springs, what CC are they.
IMO enjoy what you have, changing heads on a stock engine will get you small gains and minimal increase in speed.
1BIGJIM is offline
Old 01-30-2011 | 12:50 PM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
It is not so much that the heads are aluminum, as much as the weight savings. Also depending on the heads what makes the power is the style of head, port style, chambers etc...
Cam, intake, compression ratio, exhaust type, fuel system & overall cid all also have an impact on hp & tq.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-30-2011 | 05:14 PM
Merc did a lot of research before they used the heads that are on them now. If you are not changing everything you would be better of leaving it alone.
f_inscreenname is offline
Old 01-30-2011 | 05:19 PM
Agreed. Also, if you don't have closed cooling your asking for problems.
JTeam is offline
Old 01-31-2011 | 03:03 AM
sandman
weight and ease of repair when there is a failure are the major advantages IMO.
sandcraft is offline
Old 01-31-2011 | 05:47 AM
PatriYacht's Avatar
What heads are you looking at? If you don't know what to look for, you may end up hurting your performance.
PatriYacht is offline
Old 02-03-2011 | 07:27 PM
I thought Chevrolet did the R&D on the 502?
David Stotz is offline
