311 cabin stringers
Old 01-30-2011 | 11:34 AM
Default 311 cabin stringers
Posted this in the Formula section too.
Does anyone have a drawing or diagram of the stringers from the bulkhead under the cabin door forward? Placement and size is kinda what Im looking for. Im trying to figure out if the carpet that runs up from the cabin floor to where the cushion are is glued to the stringer or just a panel. Cause its soft as hell! Ifs it is the stringer how big wide or thick are they?
sc214cc is offline
Old 01-30-2011 | 01:23 PM
glassdave's Avatar
Neno the mind boggler
Unless it has a cabin liner the carpet is usually glued directly to the stringer.
08 OPA High Points Champion
glassdave is offline
Old 01-30-2011 | 02:18 PM
Thats kinda what i was worried about. I have found some pics of an older Formula that was getting new stringers, it wasnt a liner boat but the cabin did have a panel about 2 inches in front of the stringer that was tied in to the cabin floor and the area that makes the seat. This boat had the same stringer design that the 311 does. Just seems like if the stringers were that soft in the cabin I should be seeing stress cracks on the hull under that area,or some shifting or some sign of weakness. The only reason I know that area is soft is I went to change a light bulb in the cabin walk way.
sc214cc is offline
Old 01-30-2011 | 02:33 PM
I hope the stringers and cabin are like this pic, this is a Formula as well
sc214cc is offline
Old 02-01-2011 | 11:15 AM
Really? no body has experiance with the stringers in the cabin area of a 311?
sc214cc is offline
Old 02-02-2011 | 08:09 AM
It sounds like it has to be done either way. Get the carpet off and see what you have. Don't be scared. Here is a little motivation from when I started poking around in a 40 Excalibur.
Attached Thumbnails 311 cabin stringers-excalibur-cabin-large-.jpg   311 cabin stringers-dsc03737-large-.jpg   311 cabin stringers-excal-8-large-.jpg
TxHawk is offline
Old 02-02-2011 | 08:54 AM
Wow!! Nice job on the 40' Excalibur!!
Haley'sComet is offline
