Bravo Drives >
Bravo Drives
Bravo Drives
Old 01-30-2011 | 05:40 PM
Default Bravo Drives
On a twin set up how doe they counter rotate? Is one in forward and the other in reverse? Even though I'm shifting forwards one my shifter does one shift forward then the other shift into reverse? Is it different gears in the upper?
imagecat is offline
Old 01-30-2011 | 06:05 PM
blue thunder's Avatar
Yes there is a reverse gear and a forward gear. The shifter does act like you said.
blue thunder is offline
Old 01-30-2011 | 07:04 PM
Thanks I just never saw drives advertised as rh or lh got me thinking.
imagecat is offline
Old 01-30-2011 | 07:57 PM
Payton's Avatar
Charter Member #927
If you notice on the transome where the shifter cable goes to, on one side it is attached at the top and on the other it is attached at the bottom. So one side is running in forward and the other in reverse. some people say to swap drives every season so they wear evenly.
Payton is offline
Old 01-30-2011 | 08:25 PM
The drives are indifferent.
The rotation is determined by where the shift cables
are connected to on the shifter levers at the helm.
JaayTeee is offline
