I'm surprised this hasn't been discussed.ethanol
So, There is a stabilizer for ethanol. Why don't they blend in the stabilizer so everyone doesn't have to worry so much?
I R a happy camper because I finally rigged up a system to pump the gas out of my boat into my car! 1 down and 3 to go in my Suburban! Got caught with almost a full tank!
They do, and they do!
ValveTec Marine fuel has the stabilizer blended right in when you buy it, needs to be a certified ValveTec Marina. You can also buy the additive and add it on your own. I've run it for the past two seasons with no issues. Odd thing is that in my area it has been less money than the non treated at some of the other marinas.
I was thinking more or less on the lines the refiners should be stabilizing the fuel.
I have also added the stuff to my fuel...but is hard to trust it.
I can remember the good ole days from years ago...finding an ole car out in a pasture that had been sitting for years...with a little persuasion many could be started with the old gas in their tanks!
I spent some time with the chemical engineer from one of the top additive company's. We have had the discussion of stabilizing E10 fuel. You can only stabilize the base components of the fuel. The problem lies with the Ethanol. You can not stabilize that part. This part,(10%) is the oxygenator and octane. So yes leave 100 gallons of fuel in your tank for the winter, stabilize it, then in the spring your fuel has lost all it's Ethanol {(primarily to evaporation) (this is the issue I was focused on)} meaning if you put 93 octane fuel in the tank it is now 83 octane and will not have the oxygen content to burn and produce energy properly. Oh wait! did you only put 87 octane? Now around 77 octane. Most do not realize the engine will run ans not bad but if you push something on this fuel is where catastrophic occur due to fuel. So none of my customers have had Ethanol related issues but, I pump the tanks dry.
If you find your self in this type of situation do not use chemical additives to boost your octane. Find yourself E85 fuel and add 10%. It will get you close with compatible chemical make up.
This is an issue for fuel systems that are vented to atmosphere. Sealed systems are just that ,sealed. No loss due to evaporation.
I will leave phase separation to another thread.
