Michigan Wheel - Rapture >
Old 02-03-2011 | 01:43 PM
Default Michigan Wheel - Rapture
Need some help on a prop.
19’ X (very wide and heavy) boat with a 496ci to a Volvo 280T with a nose cone.
That aside, props are a nightmare around here. The bottom comes up fast and season after season everything changes. What was 6’ of water last fall is now a sand bar. That kind of thing. In most cases the bottom is mud, sand and some gravel here and there. No big deal but it never fails for me to take a perfect new prop out and whack the bottom in the first month (then I will go all season not doing it again, go figure).
Add in the fact that I run a Volvo Penta making props almost impossible to find over a 21P turns this problem into a very expensive problem.
Then I ran across this prop on sale;
Manufacturer: Michigan Wheel
Brand: Rapture
Material: Stainless Steel
Diameter: 14 - 1/4”
Pitch: 25”
Blades: 3
Rotation: Counter (Counter-Clockwise)
for a whole lot less $$ then any other SS prop for a Volvo that I can find.
The question is, is it junk?
The numbers look perfect for what I am looking for and if I can get through the first month this spring I can even have it bent another 2P if needed being brand new. So it don’t need to be a top of the line prop but at the same time I don’t want something that’s going to throw a blade into the stratosphere either.
What do you all think?
Thanks.
f_inscreenname is offline
Old 02-04-2011 | 08:11 AM
They're built fine for what you're looking for.
chewymalone is offline
Old 02-04-2011 | 09:29 AM
Michigan wheel Ballistic was the best prop for 2 liberators that i know. one had a 540CI Ford motor in it. i would not worry about throwing a blade!
Car Biz is offline
Old 02-04-2011 | 09:44 AM
Several years ago I had 23 raptures as backup props. 89 280 Baja sport with 400hp mercs. My normal props were 23 mirage +.
Ran the raptures for about 10 times one summer and except for being able to blow-out if trying to get on plane to fast, they worked fine. Also would slip some in turns unless trimmed down.
Boat ran 66 (GPS) any time, ideal conditions 69.2 with mirage +.
Best run 70.1 (GPS) with raptures.
But did not like solid hubs on raptures. I run in a river with some floating junk at times.
Sport 280 is offline
Old 02-04-2011 | 01:25 PM
Thanks folks.
I jumped on it. For a $155.00 bucks to my house I had to give it a try.
Sad to say it was iboats last one. If it worked out I would have got another one at that price just to hold on to.
Here is the props info;
http://boatpropellers.iboats.com/Vol...t_id=830084901
