Rusty water when I drained the cooling system
I have a 2007 496 motor with about 90 hours on it. The other day I drained the water in preparation of the latest freeze we had by removing the blue drain plugs, 2 starboard, 1 port. I noticed that the port side drained out very dirty and smelled of metal. The starboard side by the pump was clear. Im not sure what this means or if I should be worried. I do boat in salt and my routine is to flush after every trip for about 10 minutes in the driveway. I do not drain the water and the water had been in the system since about late september when I used it last. I usually only drain it if expecting a hard freeze since it stays in my garage in Houston.
So could this be from me leaving water in the system for so long and should I do any further exlporation to find where the rusty water came from?
TIA
TIA
smelled of metal ????? possibly antifreeze from winterization ?? water will always turn rusty from the block & heads ...check the dipstick and see what the oil looks like or just drain the oil out of motor and that will tell alot ..good luck
No, not antifreeze.I don't winterize in Houston, but this year I decided to drain the manifolds and fresh water system due to last weeks extended freeze. I normally lay it up after flushing even through the winter. Winter is usually only a couple months anyways.
I do have the quick drain system, but broke one of the air fittings on the water pump last week while changing the impeller therfore I had to drain the old fashoned way. I do not ever leave saltwater in the system. I flush everytime and then put it up. Maybe i need to start draining the system after every outing. Its just strange to me that the starboard side drained clear, but the port side very dirty and rusty. I think that perhaps less fresh water is getting to that side when on the hose and I just need to flush longer and then drain. Im going to check the oil this week, but It was changed in Sept and has about 10 hrs on it. assuming the oil is fine, should I be worried that the manifold could be rusting from the inside?
You are most likely correct that one side is getting less water to it than the other. My manifolds run very different temps side to side. I used to worry about it, but a quick post here found it's the same for many others. Unequal water between manifold sides seems very common.
