Better Now than at LOTO
Old 05-20-2002 | 12:20 AM
Default Better Now than at LOTO
Put the Pantera in the water today so I could check out a hub on the trailer that was getting hot.
No problem, pulled the hub and had a bearing getting bad. Replaced the bearings and seal without a problem and got a couple spare sets just in case.
Ready to pull the boat out and figured I go take a quick cruise up the river. Fire the boat up and let it warm up for few minutes while I move the truck and trailer down by the ramp. Head out of the marina and get on plane. No problems. Cruising at 3500rpms and then go up to WOT. At WOT for maybe 20 seconds and running at 5100rpms. Everthing seems perfect. At 21 seconds.........boat jerks and slows. CHIT!!!!! Yank the throttle back and here the grinding. Say good bye to the Bravo Drive. Luckily I was only a mile up river from my marina and there were a few boats out. One was nice enough to tow me in and keep me from floating to KC.
Got the boat on the trailer and see splattered Merc lube on the transom and some metal shavings on top of the drive. This is NOT good. Got the boat home and pulled the top cap, Bearings and gears are trashed.
I guess its a good thing that I haven't sold the Baja yet. At least I have a back up for LOTO this weekend. Although I'm not real happy about it.
Got a lot of options depending on what I found out tomorrow after some phone calls. Might even put the drive from the Baja on the Pantera. Just a little leary of putting a 450hr drive on heavier boat with 100 more HP. Also gonna make a call to the Ins. Co. about that submerged log I hit.
I guess the only good thing is it happened now instead of on Friday 2 mins after I put the boat in at LOTO.
Griff is offline
Old 05-20-2002 | 02:01 AM
buck183's Avatar
I like that! Submerged log...
Buck
#183
buck183 is offline
Old 05-20-2002 | 02:30 AM
eliminator219's Avatar
Default Drive gone by by
Griff
Nice way to look at it, better now than later. however, is it just the gears and the bearings or did it get the case too? Cant you get it rebuilt in time? You might look in the classified on this board there may be a replacement close to you. anyway, sorry to hear of your problems and hope that you get back in the water soon!!
eliminator219
eliminator219 is offline
Old 05-20-2002 | 09:15 AM
Katdrvr's Avatar
Griff,
I saw your boat at the Marina, looks great. Too bad abut the drive. I was down at the marina Sat. morning to run the dogs and Jeff, the guy with the Carver cruiser said lets go for a ride. OK. Get just past the power plant and boom, the port engine lets go.
Maybe I won't put the cat in at Bellevue this year, sounds like the place is cursed.
So you at the lake.
mike
Katdrvr is offline
Old 05-20-2002 | 09:49 AM
Von Bongo's Avatar
Griff that sucks.. The drive off the Baja might be in as good a shape or better even with the hours, just depends on how they were both treated.
Kat...I ain't putting a boat in there until after we get back, can't risk it now!
Von Bongo is offline
Old 05-20-2002 | 10:08 AM
Katdrvr's Avatar
Von,
I don't blame you. Jeff had just put in new transmissions and an oil cooler and we were on a shakedown run. He is bumming big time.
mike
Katdrvr is offline
Old 05-20-2002 | 05:43 PM
Good news!!!!! Got an Imco Extreme upper being overnighted and should have the Pantera back and ready for LOTO.
A BIG thanks to Marty at Midwest Performance Marine.
Griff is offline
Old 05-20-2002 | 05:52 PM
MnFastBoat's Avatar
Charter Member#157
Thumbs up AWESOME
Always glad to hear good news!!!!!!!!!!!!
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Tres
05-08-2008 07:01 AM
masher44
SBRT
18
08-12-2007 09:43 PM
Buddy OO
05-20-2005 11:05 AM
Outlawcowgirl
08-26-2004 12:07 PM
Audiofn
05-27-2002 11:03 PM
