Go Back  Offshoreonly.com > Owners Forum > Sunsation
99 sunsation 288 anniversary edition >
Old 02-14-2011 | 06:17 PM
Registered User
Default 99 sunsation 288 anniversary edition
Hi everyone,I have been looking to buy a 288 for some time and finaly found one in my area. It's a 99 288 anniversary with 454 mag. (wish it was 496ho). Anyway any of u have any info on this year sunny? Anything to watch for. Boat has 90hrs. Repo boat and was in storage from 01-08.
Thanks again.
Also if u could pm me with value?if that's allowed?
fctyson0 is offline
Old 02-14-2011 | 09:14 PM
35-38k
boatnt is offline
Old 02-15-2011 | 08:07 AM
Knot 4 Me's Avatar
496 wasn't available in 1999. Since it has sat so long, I would check to make sure the hull was properly supported and has not developed a hook. The motor needs to have fresh fuel, oil, and filters before starting. I would also pre-lube the motor before firing it up after sitting that long. I would also consider changing out the valve springs as the ones that have been compressed have most likely taken a set.
Knot 4 Me is offline
Old 02-16-2011 | 04:55 AM
Registered User
Knot 4 me. Thanks for the info. The has been run since it was stored so not sure if any of the stuff u had mentioned was done at start up.
fctyson0 is offline
Old 02-16-2011 | 12:44 PM
A reputable motor shop will rn a compression test and pull the valve covers for a couple hours labor!! Good insurance on a big investment!! Good luck with the deal, if all is in good shape it sounds like you could end up with a pretty good deal on it!!!!
Bo-G13 is offline
Old 02-16-2011 | 04:00 PM
Registered User
Wil 454 mag be underpower comp. To the 502?how much speed will I loose?
fctyson0 is offline
Old 02-16-2011 | 04:18 PM
My old 288 had the 454 MAG MPI engine in it when I bought it before I switched it over to a 525SC. It should run around 63 MPH on GPS...I would think a 502 may run 66 or 67. I loved mine....it had 400 hours on it and no stress cracks anywhere! Value would be $35,000 - $40,000 if it is very clean.
SC288 is offline
Old 02-17-2011 | 08:37 AM
Mentalpause's Avatar
454 mag was 385 hp. 502 was 415 hp. Not that much difference. That 30 hp is likely about 2 mph. You can probably get some prop work done at BBlades to make that difference up.
Mentalpause is offline
Old 02-17-2011 | 04:07 PM
Registered User
thanks everyone.ill have to start looking for someone to check the boat out for me.what would you offer if the boats in great shape?
fctyson0 is offline
