Engine guys, need your opinions on this... >
Old 05-20-2002 | 12:30 PM
Question Engine guys, need your opinions on this...
What do you think of this package:
Merlin II 540
4340 Forged Crank 4.250
4340 Forged H Rods
JE Forged Blower Pistons
Total Seal TSI Rings
Clevite H Bearings
Dart Pro 1 Aluminum Heads 345cc 2.300/1.880 valves
Dart Rocker Arm
ARP Head Studs
Cloyes Timing
Crane Solid Roller .714"/.714" 294/302 adv 262/270 @ .050, 114 L/C
Comp Solid Roller Tappets
Manley 4130 Swedged Pushrods
Comp Steel Pro Magnum Rockers
871 Blower
Looking to get some opinions on this..thanks!
alcoleholic is offline
Old 05-20-2002 | 03:17 PM
Sweet, thanks all! I ordered it all this morning!!
Old 05-20-2002 | 03:37 PM
It looks like you are using some very high quality parts. I am not a blower expert by any means, but it looks like your combo should make a stout 850 plus HP. One suggestion would be to be sure you do your homework when selecting your carbs. I personally would probably give Dean Nickerson a call and would spend a little extra to assure the carbs are right. His prices are a little high, but with the parts you have listed I don't think you are looking to get by cheap. What are you putting that motor in? Is it going to be a Bravo drive killer? I'm sure it will be pretty wicked!!!!
WETTE VETTE is offline
Old 05-20-2002 | 03:44 PM
I am looking to run this in my Cole. That is what I had in mind between 850-900 horses, this setup will push over 1000 HP with 14.25-1 compression. I will drop it to about 10-1 for pump gas. Thanks for the info on the carbs, that is why I didn't list any carb info...I want to be VERY sure about that. I don't think my Bravo 1 will like this setup...hehehe
Old 05-20-2002 | 03:52 PM
I think 2 Nickerson stage 5 1050 Dominators will be nice on that set up. Brad Perry has a similar set up to what you are building. He is slightly smaller on cam and a B & M 420 blower and I think it made 865 HP. What kind of exhaust and which Cole hull are you running?
Old 05-20-2002 | 03:59 PM
Turbojack's Avatar
I would go with lower compression (7.7-8.0)& if need be crank up more boost. More total HP can be made that way.
Turbojack is offline
Old 05-20-2002 | 05:57 PM
Ba sure to Dyno It!
cobra marty is offline
Old 05-22-2002 | 12:51 AM
mcollinstn's Avatar
Be sure to use a needle-bearing cam button and torrington bearing behind the gear. Also invest in a cast timing cover. This will prevent cam walk that will throw your timing off.
Other choice is crank-triggered ignition (eliminates spark scatter).
mcollinstn is offline
Splitdecision271
Do It Yourself, Boating on a Budget
10
07-21-2008 12:32 AM
Dock Holiday
Baja
29
10-26-2006 11:23 AM
Shah Mat
03-07-2006 05:36 AM
chrisf
01-13-2006 10:06 PM
Ratchet
11-16-2002 04:20 PM
