Bringing Back a Gel Coat Finish >
Old 02-15-2011 | 09:02 PM
Default Bringing Back a Gel Coat Finish
I have a 2003 Velocity 260. I realize this is a fairly new boat to be discussing restoring the Gel Coat Finish...... I bought the boat from a dealership in Las Vegas last winter. The boat was a repo that had been bounced around from dealer to dealer until I bought it. Anyway it is a completly white Velocity with out factory Graphics (other than the Velocity Sticker on the cowl area). While the boat appears white it isn't consistant. Nor is it a bright white. It has areas that are more of a yellowish tint than others. The Gel appears to be all original it just looks like it has faded or discolored unevenly..... I used a 3M heavy cut compound followed by the Leverage OD and polish at the beginning of last summer. I was able to get a very nice gloss, the discoloring is driving me nuts!!! Most people don't notice it until I tie up to a bright white boat. It then becomes painfully obvious...... Is it possible to bring the color back by wet sanding? Or does this discoloring sound like it might be deep in the gel? Any suggestions are welcome.
low_psi is offline
Old 02-15-2011 | 09:09 PM
Wet sand it.
redbud35 is offline
Old 02-15-2011 | 09:12 PM
Originally Posted by redbud35
Wet sand it.
Agreed. I would start with 1200 grit.
JTeam is offline
Default Fixx
sounds like you may have some vary fine dirt in the gelcoat pores,,try cleaning a area with the works toilet bowl cleaner,,if that dont do it then get some 1000 grit sand paper for a da and try wet sanding a small area then buff it and see if it makes a difference..
FIXX is offline
Old 02-15-2011 | 09:36 PM
Before you start wet sanding, do a search on how it is done. You can do a lot of damage if not done correctly.
I use 3M marine finesse-it glaze on a much older black sided boat. It works very well to restore consistent color.
Make sure sides are clean and grit free.
Use an adjustable speed polisher 1800 - 3000 rpm with a large diameter polisher.
Do a small 2x2 ft area and follow the directions on the bottle.
Good Luck
Sport 280 is offline
Old 02-15-2011 | 09:55 PM
1200 or 1000 grit and hand sand it if your not real familiar with a da sander ,u can do alot damage fast ...good luck
Old 02-15-2011 | 09:58 PM
I have plenty of experience wet sanding by hand and DA........ I used to do a lot of custom automotive paint work. I Just want to make sure I have explored every alternative before I start sanding on this one. I hate wetsanding (have yet to meet someone who doesn't). I have seen and done a few boats where they were real chaulky and wetsanding brought the gloss back. I just haven't delt with discoloring before...
low_psi is offline
Old 02-15-2011 | 10:07 PM
fire up the DA ... BIG Daddy not what ya want to hear but your only option , just did a fountain that sat in the Havazoo sun for 10 years and looks showroom new again .. get a couple 30 packs and have at it
Old 02-15-2011 | 10:31 PM
Yeah, I kind of knew this before making the post. Just hoping someone had a "mirical in a bottle" that would magically get ride of the discoloring........... My problem is I have a bad back (2 rods & 4 bolts) so this is going to take more than a couple of 30 packs for me...... Wetsanding isn;t something I want my friends doing for me..... This is one of those if you want it done right, do it yourself areas. So I will just have to do a little bit at a time and not push myself....... I will have to wait until spring to get it out from shrink wrap anyway.
low_psi is offline
Old 02-15-2011 | 10:59 PM
would be toilet bowl cleaner ( The Works ) to rid the yellowing & discoloration but it will be back every weekend , sounds like yur lookin forward to spring but not to wet sanding
