Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Gelcoat buffing/sanding question >
Old 02-16-2011 | 08:52 AM
Default Gelcoat buffing/sanding question
Question for the experts. The deck of my boat needs a little work. Its hard to explain its condition. After a nice wax, it the surface looks flat and shiny, however, when you look deeper into the finish, it looks chalky underneath it, if that makes any sense. So if you look at the deck from a angle, it looks good. But if you stood on the deck, and look directly down into the finish, you see the chalkyness, or maybe its a combination of dirt, oxidation, etc, under the finish.
So, would a heavy compound or wet sanding then buffing bring back that deep luster?
MILD THUNDER is offline
Old 02-16-2011 | 09:25 AM
pic
Attached Thumbnails Gelcoat buffing/sanding question-75.jpg
Old 02-16-2011 | 09:50 AM
Registered User
It is hard to tell from the picture but it looks like a good wet sanding and polishing would bring that deck back very nicely. The colors dont look to faded and the white doesn't look to bad either.
HiPerf360 is offline
Old 02-16-2011 | 09:52 AM
get the 1000 grit paper & the da ready
Old 02-16-2011 | 10:11 AM
Looks like i might have to start sanding! Might as well do the fairing too. That was painted, and does show some orange peel.
so wetsand with 1000 then buff? or 1000, then 1500, then buff? Thanks!
Old 02-16-2011 | 10:18 AM
1200,1500,2000,2500, & buff the ch!t out of it
Old 02-16-2011 | 10:28 AM
Slave driver!!!!!
Looks like i have a job ahead of me!! But that mirror like finish really gets my pants tight, so i better get to it.
Old 02-16-2011 | 10:38 AM
Slave driver!!!!!
it will be worth the effort
Attached Thumbnails Gelcoat buffing/sanding question-bunks-003.jpg   Gelcoat buffing/sanding question-bunks-015.jpg   Gelcoat buffing/sanding question-fountain-006.jpg
Old 02-16-2011 | 10:57 AM
Slave driver!!!!!
I did 600 , 800 , 1000 , 1500, compound, polish, wax on my 24 Cig. It was IMRON, so you shouldn't need to start as low as I did. I really thought I would loose the use of my arms about halfway through the project You could read the wax bottles on the shelf next to the boat in the reflection when I was done.
Results were spectacular, so it was worth it. Are you sure there's enough winter left to tackle that 38!??!
RT930turbo is offline
Old 02-16-2011 | 11:00 AM
