What flush out hose connectors are there...?
Just wondering what is out there other than the "cheesy" Perko set ups?
http://www.saltysmarine.com/index.ph...52ef00ffb4e487
The one I have is not that well made, sticks out from the hull a fair distance and it actually leaks when the hose is connected....I also worry because if the plastic cap is damaged obviously air is sucked into the system and an over heating issue can arise.....just wondering what everybody is using?????
I have been considering buying the prestone flush kit for radiators from an automotive store. They have three different sizes for whatever hose you need. Then you wouldnt have to deal with a bulky piece of junk on the side or back of your boat. Just have to deal with opening the hatch to connect the hose. Just my .02 though.
I have a flush out port built into my sea strainer in the engine bay but that is what I am trying to avoid, dragging a hose over the side of the boat and under the hatch, far easier for me to just hook up the hose from the outside of the boat, plus I already have a fitting there so was looking for a better alternative, thanks.
I did find this, pricey, anybody using this?
http://www.cpperformance.com/p-13742...connector.aspx
The set up I have now, I shut off the valve just before the sea strainer to the leg pick up and hook the hose to the hull mounted flush out port that goes to the top of the sea strainer, works well but as I said, the Perko one that is there is cheap and nasty.......
