vinyl wrap costs?
Old 02-21-2011 | 12:55 PM
Default vinyl wrap costs?
anyone have ballpark figures on what vinyl wraps cost for the following boat sizes?
27'
35'
42'
and does anyone know how slippery they are to walk on?
fossilx is offline
Old 06-29-2012 | 10:15 PM
Does anyone know what it would cost to wrap a 27' Baja 272?
Can you wrap the top deck as well or would that be too slippery?
fossilx is offline
Old 06-30-2012 | 03:51 AM
Default It varies a little bit...
...but generally you can calculate at $10/sq ft for estimation purposes.
There are different materials used depending on wrap. The ones I have used/seen might actually be less slippery after a little time in the sun.
BoatShow239 is offline
Old 06-30-2012 | 09:04 AM
glassdave's Avatar
Neno the mind boggler
Keep in mind when estimating the square foot it is square foot of material used in the process not actual exact sq ft on the boat. Some of these generate a large amount of end cuts and waste by virtue of their shape and complexity. If you have an area that is say 26 inches wide you may be charged by the linear foot if nothing else can be nested in the remainder of a 50 inch wide vinyl as an example. Even still (although i am not a fan) its a pretty good alternative to paint, and printing technology has come a long way. My guy can even print metallics and foils, cool stuff.
08 OPA High Points Champion
glassdave is offline
Old 06-30-2012 | 11:32 AM
Default glassdave is 100%...
...on the money! No pun intended!
In just the last few years the quality and variations of media and ink has improved in quantum leaps. I have even seen ones which had a mild holographic effect!
Sometimes when you see the raw product you will wonder "what are they doing?" Then when the artist has done their magic with the cutting and trimming your concerns will generally vanish.
Many of the newer products experience little or no fade and unlike some of the older wraps, if you decide to remove they are much easier to take off.
Just as a personal note, sometimes less is more. While a very complicated graphic might look cool on paper, on a large surface it can become too complicated and not get the desired effect!
I wrapped my 26 foot Powerquest. Some vinyl on the bow but not a full wrap...Cost was $1300 to have custom vinyl printed (the skies the limit on the design) and I paid another $700 to have it installed. $2000 total. It was well worth it and alot cheaper than even a basic paintjob.
Powerquest_Baby!! is offline
Old 06-30-2012 | 12:44 PM
Does anyone know a good vender for wraps in the New England area?
JETTDOGG is offline
Old 06-30-2012 | 06:56 PM
Default fixx
I havew a friend that does wraps,,Kontagious Kolors 630-543-7900 ask for brian..
FIXX is offline
Old 07-01-2012 | 10:13 PM
I had my 42 lightning wrapped by SignZoo about 4 years ago and I have seen many wraps and money for money they do a FANTASTIC job. They use 3M material and my sides lasted 3 years and still looked new. I had them replace the material above the rub rail after year 2 just because of fender rash and a few dock nicks but it was easy since they just reprinted the material. i worked with them for 4-6 weeks just to get the design just like I wanted it and it grabbed attention wherever I went. Sold the boat a couple months ago and removed it but it could have lasted another couple years easy.
I paid about $5-6k total but that was them coming from FL to TN to do the install. Wraps are much like other things... you can get it done for less but do you really want to? I have seen so many with bubbles and fading etc... If you want to keep the boat and want a quality job don't save yourself a few hundred bucks! You do get what you pay for...
gofastlvr is offline
Old 07-03-2012 | 07:33 AM
fabin61's Avatar
Let's see some before and after pics! I have 322 Baja that has some outdated colors and I have attached a pic. I wanted to change the two teals to Candy Apple Blue and Sunburst Orange. So just the stripes not a full wrap. I was quoted $800-$1100 a side. I thought that was high but based on what you paid it may not be for off unless you did a full wrap.
fabin61 is offline
