removing graphics ???????
Guys. Where do you come up with this stuff? Acetone???? Read the label. Specific useage and wow, look at the ingredients and warnings. I thought for a minute that I was on Speedbake.
From the professionals for professional work.
http://www.rapidtac.com/products/remover.html
I dont know if its too late or not, but if they are vinyl stickers, use an eraser wheel! It can be found at most auto parts stores in the body/paint section or any auto paint house should have them. Looks like a disk about 4-5"diameter, 5/8ish thick, has arbor to chuck up into a drill and is made of pencil eraser type material! Works awesome! Never will I attempt to use a heat gun or solvent ever again, does not damage paint and works fast. Good luck.
example here
http://www.amazon.com/3M-7498-STRIPE.../dp/B0013HHNHC
example here
i used to use it by the quart, 3M has discontinued it, it was 083380.. use a product called rapid remover, smells like oranges and 100% biodegradable.. just rub it on and let it work, wipe off the adhesive. clean up is a breeze.
example here
example here
