Who's running stainless marine manifolds w/standard risers >
Old 02-25-2011 | 07:20 AM
Default Who's running stainless marine manifolds w/standard risers
Ive got SM manifolds currently with the standard risers with silent choice exhaust on a 502mpi. Rebuilding right now and im concerned with reversion issues when running bigger cams. Wondering what you guys are running for cams with the same setup and if you had reversion issues or not. thanks.
dagah2x is offline
Old 02-25-2011 | 07:37 AM
I have a 502 mag with a whipple installed by the previous owner, not sure of the cam but suspect it is not stock. Late last summer I had a set of IMCO Power Flow manifolds and SS short risers installed so I could keep my silent choice. Long story short i had a reversion issue with the short risers. Young Performance Marine cleaned up the mess and extended the short risers doing away with the silent choice. The risers look great! hard to tell they were not the long risers to bergin with.
bigredbaja is offline
Old 02-25-2011 | 01:26 PM
It all comes down to lobe separation. When you start to tighten it up the risers have to get taller.
f_inscreenname is offline
Old 02-25-2011 | 05:36 PM
custom cam but i think its going to be 114, not sure on duration yet.
dagah2x is offline
Old 02-27-2011 | 06:57 PM
anyone else?
dagah2x is offline
Old 02-27-2011 | 07:54 PM
Send you old ones back to Stainless Marine and have them make what you need it's not as much as you think.
our old 272 383's cam from Bullet 223/231 .530/.548 110 center line 425 hp and in our 382 515's cam from Bob 234/238 .648/.637 112 centerline 7/4 3/2 swap 600hp
Attached Thumbnails Who's running stainless marine manifolds w/standard risers-kims-pix-136.jpg   Who's running stainless marine manifolds w/standard risers-s7300094.jpg
formula 382 sr-1 is offline
Old 03-01-2011 | 07:07 AM
yeah I could have my extended but the big deal is I dont want to lose silent choice.
dagah2x is offline
Old 03-01-2011 | 04:51 PM
Call them, I think they can tell you how big of a cam you will be able to run !!!!
Old 03-01-2011 | 08:00 PM
I couldn't agree more. Jerry from Stainless is the man. I met him in person at his plant a month ago. He pressure tested a used set of manifolds for me and sold me some used standard risers with brackets for a VERY reasonable price. Give him a call. I'm sure he will be very helpful!
twinskrewd is offline
Old 03-02-2011 | 05:42 PM
Who's doing your cam?
jeffswav is offline
