Looking for moderate HP increase 502 mag MPI >
Old 02-28-2011 | 09:05 PM
Default Looking for moderate HP increase 502 mag MPI
I have pulled my 97 502 mag MPI for rebuild with only a little over 200 hrs on it. It is using oil badly. I am intrested in gaining some HP in the process but not excessive. I have tossed around the idea of a whipple or pro charger but haven't made a decision on a supercharger or just building up and living with that.
My question is, what are some of the combinations you guys have built on a reasonable budget and had good luck with? What kind of numbers did that put out?
Any info would be a big help.
Justin
jjmoos is offline
Old 02-28-2011 | 10:27 PM
A Whipple is not "moderate hp" and whats a reasonable budget?
A whipple is 10k or more to do it right, not counting the cost of the rebuild. Exhaust is $2500-5000 plus ecm tuning, etc. Tell us what you want to spend and some experts will help you out
rexcramer1 is offline
Old 03-01-2011 | 06:17 AM
jjmoos - I have the same boat as you and have done some decent upgrades that didn't break the bank. Shoot me an email [email protected] and I'll be glad to chat with you.
Griswald is offline
Old 03-01-2011 | 06:31 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Indeed, a whipple will add more power & expense.. Great units tho.. Budget will be the biggest determining factor on how far you could go...
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 03-01-2011 | 08:57 AM
Im surprised your engine needs a rebuild at 200 hours. They usually go 500+ before any problems, but i suppose anything can happen.
send a message to Eddie at "Young Performance" on here. He is in Tennessee. Top notch work, top notch guy. He will probably have several options for you.
MILD THUNDER is offline
Old 03-01-2011 | 06:26 PM
id say procharger.....or even a good heads/cam/intake package would be the best hp/$.
after all.....thats what the limiting factor for most upgrades is
2tonchevy is offline
Old 03-02-2011 | 01:33 AM
How much do you consider "moderate" and what is your budget for the upgrade. A bigger cam, ecm upgrade and exhaust will get you about 60-70hp and will cost about 3-4k.
Griff is offline
