First season with this boat and have some questions before I do some damage. >
Old 03-01-2011 | 05:23 PM
Fountain4402's Avatar
Default First season with this boat and have some questions before I do some damage.
Not a first time boat but first time to fountain and high performance. And I have some questions, last owner didn't do any work him self and I am a Do it yourselfer.
1. The boat I have is a 91 Fever with 454 MAGS, what kind of oil and how much?
2. Right now it has a marine filter on it, what would be the normal car filter number on the oil filter so I can pick up a FRAM, stp, etc.
3. Besides changing oil, drive oil, checking all fluids etc, is there anything that I am missing?
Fountain4402 is offline
Old 03-01-2011 | 05:49 PM
eddie's Avatar
Should be around 8 quarts for each motor. I use Mercury oil.
I use the Merc Racing filters they are around $14 each.
If the sea water pump hasn't been changed it's a good idea to put new ones in so you don't get stuck on the water one day.
eddie is offline
Old 03-01-2011 | 06:35 PM
thanks yeah I did one pump last fall before storage as it blew while I was storing it. Any idea on the weight of the oil and filter numbers
Old 03-01-2011 | 06:44 PM
sommerfliesby's Avatar
I run Mobil 1 15-50.
sommerfliesby is offline
Old 03-01-2011 | 06:56 PM
You really should get a factory manual and go with what it says. My old Merc 420's called for straight 40 wt and I used Castrol with Fram HD filters and got 700+ hours out of it with no issues.
JTeam is offline
Old 03-01-2011 | 07:00 PM
yeah ive tried to get a manual even called and lady said they didnt have them and basically said they didnt say much. So yeah id love to have a manual.
Old 03-01-2011 | 07:14 PM
I change my impeller every winter regardless.... To simple of a thing that could cost you some major dough.
FuelinAround is offline
Old 03-01-2011 | 07:33 PM
8qts???? My 502's hold 6 @ the absolute most....
jmoore1225 is offline
Old 03-01-2011 | 08:28 PM
monstaaa's Avatar
7.5-8 qts pendind how well you evacuate old oil. merc 25-40 or 50 oil. blend or full synthetic available. merc filter.
if u want to use wix they are good as well as they make mercs racing filters i believe.mobil1 15-50 is good oil as well. change your thermostats.back flush cooling system thoroughly. flush block routinely. and keep in tune. this and what is said above should give you a pretty trouble free season.. best of luck.
monstaaa is offline
Old 03-02-2011 | 07:17 AM
http://shop.ebay.com/i.html?_nkw=mer....c0.m270.l1313
Back4More is offline
