oil coolers.
Old 03-01-2011 | 09:30 PM
STRAIGHTPRIORITY's Avatar
Default oil coolers.
where are yours mounted?
bell housing.
under motor.
remote (on a stringer)
STRAIGHTPRIORITY is offline
Old 03-02-2011 | 07:22 AM
anyone?
Old 03-02-2011 | 08:41 AM
Over the bell housing. 3x18
TexomaPowerboater is offline
Old 03-02-2011 | 08:46 AM
i have #6 bellhousings,the coolers are part of the bellhousing.
mike tkach is offline
Old 03-02-2011 | 09:46 AM
i have these monsters. and i have had them mounted on bell- housing but makes it so tight back there. i wanted to mount them under the motor somewhere or on a stringer but don't want the bilge to look cluttered. looking for suggestions.
http://www.eddiemarine.com/store/car...l&p=13576&c=47
Old 03-03-2011 | 01:07 PM
they have some stringer brackets available but dont look to strong.
Old 03-03-2011 | 05:16 PM
I have a similar cooler from Mr.Kool. I mounted mine on the stringer with the brackets. They have been holding up fine.
I mounted the brackets/cooler when the motor was out though.
whoya is offline
Old 03-03-2011 | 09:23 PM
mine are out rite now too... getting ready to put them in so wanted to figure out where i should put them... i want the bilge to look as clean as possible.
Old 03-03-2011 | 09:38 PM
mikes280's Avatar
is your set up a bravo boat , if so i took a peice of 3/4 inch box tubing and ran it from the little foot on the bottom of the bellhousing forward . I made a drop down leg off the block where stock motor mounts go out of a peice of flat stock , it held the box tubing at the front . Then i mounted the cooler to the box tubing with 2 wrap around hangers. it has worked great for 6 years with no problems . This way you can't see it and if you pull the motor it stays with it and all the plumbing.
mikes280 is offline
Old 03-04-2011 | 07:18 AM
I trimmed a little out of my motor mountswelded a half of a piece of stainless tubing ( cut lengthways) and welded it to the inside of the mount with braces. These were 3x18 and essentially were right behind the alternator along the side of the block.
to secure them i used stainless hose clamps with a piece of rubber between them and the tubing.
As Mike said above this way when you pull the engine everything is self contained, and very secure.
Dave
delsol is offline
