Trailer Weight Alum Vs Steel
Old 03-03-2011 | 07:23 AM
Default Trailer Weight Alum Vs Steel
anybody have a idea on the weight difference between a tandem axle trailer aluminum vs steel ? thanks Rob
ezstriper is offline
Old 03-03-2011 | 08:22 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
General rule of thumb; Aluminum is 2/3s the weight of Steel.
A Myco or similar welded C-channel Aluminum trailer will be heavier than a bolt together Aluminum I-beam trailer.
Sydwayz is offline
Old 03-03-2011 | 09:15 AM
a 38 Myco steel weighs in at 2200 pounds, the same Myco aluminum weighs around 1200 pounds !!
DareDevil is offline
