502 MPI upgrade results
Old 03-04-2011 | 10:40 AM
Default 502 MPI upgrade results
I just got this off the dyno a couple days ago and think this is a great little package for the 502. The cam is from Bob Madara, the tune is from Mark Boos. Stock 502mpi with the intake dividers cut down and a bit of porting, stainless marine exhaust, run on the dyno with all accessories, wet exhaust through GGB mufflers. It idles at 600rpm and the tune was perfect. You could bump the rev limiter up and make a bit more. It made 508hp just before it hit the limiter at 5350rpm. Thanks again to Bob and Mark!
Attached Thumbnails 502 MPI upgrade results-502mpidyno.jpg   502 MPI upgrade results-haydendyno.jpg   502 MPI upgrade results-hayden502.jpg
HaxbySpeed is offline
Old 03-04-2011 | 10:44 AM
Very nice numbers, clean assembly.....
FogduckerIII is offline
Old 03-04-2011 | 02:32 PM
Looks like you need to turn the rev limiter up to 5500!
Thanks for posting the results. I guess its not that hard to make over 500hp with the stock 502 intake
rexcramer1 is offline
Old 03-04-2011 | 03:19 PM
So is it basically a stock mag with bob madera cam, a little intake porting, stainless marine manifold, and everything else stock? Nice numbers!
MILD THUNDER is offline
Old 03-04-2011 | 05:35 PM
Yes, and a tune from Mark. I upgraded the springs when I did the heads, which are stock rebuilt, and everything else is factory. That's why I thought it was worth posting, it's a pretty simple combo for anyone to duplicate. Just call Bob.
Old 03-05-2011 | 07:50 AM
vette131's Avatar
nice flat torque curve!
vette131 is offline
Old 03-05-2011 | 12:33 PM
ballon78's Avatar
nice! Did you go to roller rockers, tiebar lifters and new pushrods? or running all stock? I would like to duplicate your set next year on a set of 502efi 96's.
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 03-08-2011 | 07:42 PM
Yes, I used roller rockers, stock lifters and pushrods.
Old 03-09-2011 | 08:16 PM
about how much did all this cost? Sounds like some nice mods for little.
apaolillo is offline
Old 03-11-2011 | 12:13 PM
Can you explain "a tune" for me? and would something like this work on a carb. 502 or is this strickly for an MPI?
Thanks...ts27
Thunderstruck27 is offline
