Advice Needed - Converting 3 to 2 motors >
Old 03-05-2011 | 10:58 AM
Default Advice Needed - Converting 3 to 2 motors
Hey guys, here is a question for the technical guys.
I recently purchased a 1995 Sunseeker Apache 45', it was a repo and the 3 motors (502's) are missing, but the 3 bravo drives are still in place. Now, I have noticed that these also came with just 2 motors and I am wondering if I can convert it back to 2.
Is it as easy as just removing the center drive and have a glass guy cover over the hole? I think I would either have to change out the shifters(3) or just leave them as is, with 1 being not connected.
The big question is, will the 2 remaining outdrives be too far apart on the transom? I have looked at some pics of the boats with 2 drives and they seam to be in about the same spot.
I attached a pic of mine now.
Thanks for the advice.
Oh and I know it will slow her down, but I don't need her to do 60MPH, I have a Donzi Z33 for that
VancouverMark is offline
Old 03-05-2011 | 12:29 PM
If you do that, you will put all the stress from the third drive onto the other 2. Its a big heavy boat and it will be hard on just 2 Bravos.
Griff is offline
Old 03-05-2011 | 12:47 PM
Default Fixx
like griff said,that's a heavy boat and will need something stronger then just bravos..your best bet would be to sell the bravo set ups and find some speed master set ups or Arneson surface drives and use them in a staggered configuration..going from 3 to 2 motors your going to have to cut out the stringers and glass everything back up including all three holes to get the proper x dimension for the drives to work with each other,just remomving the center engine and drive may be to far apart to get any speed out of the boat..
in the long run it would be cheeper to put 3 502's back in the boat and go boating..If you do deside to glass the hole up and use 2 502's i would look into a set of bravo III drives which may work,,,,for the time being ..
FIXX is offline
Old 03-05-2011 | 07:29 PM
Default ahh
Ahhhh....thats what I was worried about. I do not want to move the motors and redo stringers ect. So I guess I am looking for 3 454's or 502's !
Thanks guys
Old 03-05-2011 | 07:55 PM
I would get 502's if I could, as the resale will be much better down the road with 502's as opposed to 454's.
rexcramer1 is offline
Old 03-08-2011 | 09:10 AM
Default Update
I spoke with the lead service Manager at Seattle Boats, a Sunseeker Dealer. He seems to think all I have to do is remove the center drive, glass up the hole and go boating. He sees no need to move the engines or stringers, apparently the hull stringers are the same from the twin to the triple set up.
I am waiting to hear back from a guy name Andrew at Sunseeker Costa Mesa Ca. Apparently he is the best guy on the West Coast.
Cheers
Old 03-08-2011 | 10:12 AM
t500hps's Avatar
21 and 42 footers
Do you have the boat yet.....Is it coming from Richmond VA? (I don't know the boat but your description fits one that is sitting here locally)
t500hps is offline
Old 03-08-2011 | 10:51 AM
Yup, thats mine. I do own it now. It is getting loaded on a truck and shipped out west.
Cheers
Mark
Old 03-09-2011 | 06:56 AM
2 Diesels.....
ezstriper is offline
Old 03-09-2011 | 08:22 AM
Default Final Update - Direct from Sunseeker
Good morning
Yes he could install just 2 engines but would need to reposition engine
beds, modify the transom and
would have to purchase Bravo 3 legs to be able to fit bigger props or he
will have trouble getting up
on the plane.
With a clean hull and 3 good engines a top speed of around 48 - 50 knots
can be achieved.
With a clean hull and 2 good engines a top speed of around 38 - 40 knots
can be achieved.
It would be cheaper for your customer to purchase 3 new engines than carry
out the extensive modifications
to engine beds, transom and buying 2 new Bravo 3 legs with suitable props.
But if money is no object then why not fit twin Seateks on Arnessons drives
and fly at 70 knots !
Trust this assists
kind regards
Steve
Steve Butcher
SuperYacht Warranty/Support
So, I am on the hunt for 3 engines If anyone has some, please let me know.
