best valve covers for roller rockers 502 Mag >
Old 03-06-2011 | 11:20 PM
Default best valve covers for roller rockers 502 Mag
Putting roller rockers on my 1992 502 mag motor.Stock valve covers dont fit.Any advise on what to use from Merc, don't want to go aftermarket.
bunky1957 is offline
Old 03-06-2011 | 11:45 PM
AIR TIME's Avatar
aftermarket has some nice stuff, but I used a pair of older merc 540 500hp bulldog covers once. bill at Diamond marine [302 521 0123] has some nice prices and lots of covers. polished or in colors. good luck
AIR TIME is offline
Old 03-07-2011 | 12:56 AM
Why do you not want aftermarket?
You may be able to use your stockers if you grind out the little titties on the under side of the cover. You will also have to remove the baffle. You may have a problem with oil wanting to come out of the pcv grommet.
CP Performance has some nice cast aluminum covers that are pretty reasonable. Here ya go.
http://www.cpperformance.com/p-13494...-oil-plug.aspx
Eddie
Young Performance is offline
Old 03-07-2011 | 01:00 AM
As Eddie said, stock valve covers will fit with slight modifications. All you need to do is grind off the oil drip tabs on the underside of the valve covers. Depending on which rocker arms you use, you may have to either modify the baffle or grind off a 1/4" of the corners on the #1 and #7 intake rocker arms. That is what Merc did on 525SC's and HP500's. The new Crane Golds should fit without any mods to the baffle or grinding the corners.
Griff is online now
Old 03-07-2011 | 07:21 AM
Underdog88's Avatar
Veteran: Navy
As they said above plus... Mr. Gasket Makes an extra thick VC gasket.
I bought a couple cheap chrome sets from Summit for like 30 bucks a pair and had no drippers to grind off. I'm both cheap and lazy
Underdog88 is offline
Old 03-07-2011 | 01:21 PM
Default HP500 valve covers
Would an HP500 cover work? Didn't they have roller rockers from the factory.
Old 03-07-2011 | 01:24 PM
They are the same ones you have with the little titties (drip tabs) removed.
Old 03-07-2011 | 01:44 PM
JasonSmith's Avatar
A Dremmel is your friend. It takes longer to take the covers off than it does to grind out the tabs.
JasonSmith is offline
