Misc parts for sale... Exhaust, Mufflers Deck Hardware... >
Old 03-08-2011 | 03:53 PM
Default Misc parts for sale... Exhaust, Mufflers Deck Hardware...
I am cleaning out the garage of spare or left over boat parts, all prices are “or best offer” and for items listed in groups they cane be split up if need be:
Corsa Marine Mufflers 2 pair (4) 4.5” clamp on for big power applications very little use in fresh water nice condition comes with T-Bolt Clamps NOTE: someone has cut an extra slot where the clamp goes. $225 per pair
The Exhaust parts below came off my boat when I went to a full dry exhaust. I had added and replaced a bunch of parts trying to trouble shoot a water in oil problem I was having with my new motors. It turns out it was reversion not intrusion. So all this stuff came back off:
Transom exhaust tips 2 pair (4) 4” in good usable shape, these came on my Boat when I got it. One is slightly shorter on the transom side. The need polished and have been drilled for the CP Performance burn proof exhaust tip internal flappers but I installed them with a long stainless Allen bolt instead of welding the pivot pin on the tip. $40 per pair
4” Shields Exhaust Hose cut for joining the exhaust manifold to the transom tips (4) these were used for about ½ a season (20hrs) they are in nice shape lots of use left on them. $10 per pair
CP Performance burn proof exhaust tip internal flappers 2 pair (4) 4” I had put these in the existing tips on my boat that had no flappers These were used for about ½ a season (20hrs) they are in nice shape lots of use left on them. $25 per pair
Hardin Marine External Exhaust Flappers 2 pair (4) 4” I had put these on the existing tips on my boat that had no flappers These were used for about ½ a season (20hrs) they are in nice shape lots of use left on them. $25 per pair
Sea Dog 8” Stainless Cleats (6) these are the ones that came on my boat when I got it but they had just been changed (1999) they are in nice shape. I installed some flush mount ones. $60 for the set
Sea Dog Stainless Line Chocks (2) these are the ones that came on my boat when I got it but they had just been changed (1999) they are in nice shape. I installed some flush mount ones. $15 for the pair
Stainless Flip Top Deck Mount Fuel Fills for 2” hose (2) these are the ones that came on my boat when I got it but they had just been changed (1999) they are in nice shape. I installed some flush mount ones. $50 for the pair
Sen Dure Oil Coolers 2.5” X 16” (2) these are the ones that came on my boat engines when I got it but they were too small for the new motors (575ci) so I had to go bigger. They come with brackets and some fittings $150 for the pair
Alternators 65 amp one wire hook up (2) these where rebuilt and had one season (50hrs on them before I upgraded to 100 amp unit to feed the new motors fuel injection pumps. $ 50 for the pair
Starter BBC Large (non-gear reduction) Block Mount Style it is a little ruff looking on the outside but was rebuilt and had one season (50hrs on them before I upgraded to high torque unit to turn the new motors. $25
Starter BBC Small (gear reduction type) Block Mount Style it was rebuilt and had one season (50hrs on them before I upgraded to high torque unit to turn the new motors $25
Stainless 3 Step under swim platform mount ladder this came on my Boat when I got it. It is in need of a polishing but is usable $20
HP 525 EFI Fuel Rail Sensors (2) these came on the used fuel injection set ups I bought and had no use for. $10 for the pair
Autometer Oil pressure Sensors I bought these and used them for 10min before I realized they were not compatible with my new gauges. $30 for the pair
Guest 30amp Battery Charger SOLD
Last edited by whodathought38SS; 03-10-2011 at 07:24 AM. Reason: battery charger sold
whodathought38SS is offline
Old 03-08-2011 | 05:11 PM
Default Ladder
Can I get a pic of the ladder [email protected] . Thanks Eric
Esal is offline
Old 03-08-2011 | 06:30 PM
Does the battery charger have a model# on it?
vindicator101 is offline
Old 03-08-2011 | 07:13 PM
The Battery Charger is a Model NO. 2530A 13.6VDC 30amps continuous and 50amps intermittent
Old 03-08-2011 | 07:22 PM
Eric,
Pictures have been sent.
Thanks,
Andy
Old 03-08-2011 | 11:19 PM
Registered User
Default oil coolers
can you send oil cooler pics to : [email protected]
aaronniquette is offline
Old 03-09-2011 | 06:33 AM
mr weazelle's Avatar
Do you have any pictures of the Corsa mufflers? I would like first right of refusal if possible.
mr weazelle is offline
Old 03-09-2011 | 06:38 AM
Mr. Weazelle,
I will need you email to send them to tonight when I get home from work.
Aaron,
I will send you pics of the oil coolers tonight as well.
Thanks,
Andy
Old 03-09-2011 | 07:06 AM
hey pics of the corsa mufflers please
[email protected]
adk61 is offline
Old 03-09-2011 | 08:59 AM
PM Sent on the oil coolers and the alternators
Haley'sComet is offline
