E-Top Plumbing >
E-Top Plumbing
E-Top Plumbing
Old 03-08-2011 | 10:02 PM
tcelano's Avatar
Default E-Top Plumbing
I did a search for this, but came up empty. What are people's recommendations on plumbing for water supply to CMI E-tops? In pictures I see, about half use only the lower distribution rail, and the other half use the elbow jacket supply as well.
Thanks!
tcelano is offline
Old 03-09-2011 | 10:08 AM
We just run two hoses (1 port 1 Stb) from the the water exit at the front of the intake manifold to each CMI water distribution tube. Then you use a jump hose from the top of the manifold to the tail pipe....many years use...no issues.
BenPerfected is offline
Old 03-09-2011 | 10:38 AM
Panther's Avatar
Frank's Marine Service
the elbow jacket supply is for engines with circulating pump and t-stat. If you don't have the t-stat housing and circ. pump then just run it to the bottom.
I believe the idea is to restrict water flow in the header tubes until the engine is up to operating temps but I personally don't think it's very effective... Who knows...
Panther is offline
Old 03-09-2011 | 02:10 PM
It depends on which T stat housing you have. My 525SC had 4 outlets from the T stat housing and my 502mpi's only have 2 outlets.
Griff is offline
